2006 f250 sd no reverse or neutral
just bought the truck symptoms are no reverse, when in gear hit the gas pedal and the rpms go down , put it in neutral wants to drive , shut the key off put in neutral I can roll it back , when I start it in neutral goes in drive , no more neutral again need help
friend told me that yesterday too I was going to drop the pan and see if there was any metal in there, and change out the 7 solenoids . I checked Colum and undid cable so I can shift trans manually , I saw that the owner put new transmission lines and external filter I think they dropped the pan too I can see gasket sealer the truck has a plow 104,000.on it ,is the clutch replacement big job
The way to replace the clutch is to take the trans out of the truck, completely tear it down, and do a full rebuild.
AKHunter93
30
11-06-2019 03:16 PM
jacob_powerhouse
09-10-2018 06:41 AM
1972fordhighboy2
09-28-2016 12:29 PM
fairhardware
04-09-2011 07:47 PM
