ETIS and "Window Sticker" site won't pull up 2017 SD?
Hi guys - I'm looking at a lightly used F-350 Super Duty, but am having a tough time confirming the options it was built with outside of those easily visible. I went to the Mike Murphy Ford website that allow you to view the original Ford window sticker and all I get is "Please check back later. The window sticker has not been released for this vehicle". Failing that, I figured I'd pull it up in ETIS and see what it was equipped with. ETIS will confirm the correct year, model, and color and reports back "F-Series Super Duty, 6.7L 4V V8 T/C Diesel, Ingot Silver Metallic 2", but nothing else...no options, no exclusions, no detail.
I can try to put a call in to my local Ford dealer (although the truck is out of state), but any other way to pull up detail online? I've tried a number of times over various days using various computers and browsers with no luck at all.
FWIW, the VIN is 1FT8W3DT4HED43562 if anyone can figure out a better mousetrap!
Thanks...
Jason
Thanks...
Jason
It's a base XLT doesn't look like it has any options.
3.55 gear
https://beaverdamautos.com/2017-Ford...4HED43562.html
3.55 gear
Thanks Robb81! I was hoping it had a plow package, 5th wheel prep, and at least an LSD (I didn’t see the E-Locker switch). I might be able to solve for the first two, but I would expect it would be pretty expensive to retrofit the rear axle with the OEM locker. Might have to pass on this one and look for a truck with the options already built in.
Thanks!
Jason
Thanks!
Jason
You have to make a free account and login to ETIS to see any details, so I just grabbed it for you:
Primary Features
Build Date: 03.04.2017
Vehicle Line: F-Series Super Duty
Body Style: Double Cab (3/4 Door)
Version: 350 Series
Engine: 6.7L 4V V8 T/C Diesel
Transmission: 6 Speed Auto Trans (6R140)
Drive: LHD 4WD (PTD)
Axle Ratio: 3.55
Emission: 50 State Emission Requirements
Air Conditioning: Manual Air Conditioning
Territory: (+)"USA"
Paint: Ingot Silver Metallic 2
Minor Features
Medium Earth Gray Interior
Less Rear Mudflaps
Front Door Scuff Plate - MIC
Less Front Fenders
Less Front Mudflaps
Decals - 4X4 Red/Silver Drw
Tailgate-Black Handle Centre Latch
Less Tailgate Applique
With Power Tailgate Lock
With 8' Styleside Box-Steel
4 Cargo Tie Down Hooks - Inside
Less Pickup Box Extender
Less Load Box Bedliner
Less Bed Ramps
With Base Payload Package
175.5 / 4457.7MM Wheelbase
XLT
(-) Version Packages
Kentucky Truck Plant Build
Less Special Equipment Package
Pickup
Less Tractor/Trailer Equip PKG
14,000 LB. GVW
Less Appearance Group
Less Exterior Appearance Pack
With Power Equipment Group
Less Memory Package
Feature Content Group 1
Kentucky Truck Plant Build Only
With English Language Label
Owner Hand Book Pack
Less Water Wading Equipment
Brand Owner - Ford
With 4 Ton Hydraulic Jack
With Power Front Windows
With Electric Rear Windows
With Privacy Glass
With Fixed Rear Window
Less Heated Rear Window
With Medium Length Overhead Console
Less Floor Mounted Console
Less Floor Mat Kit
Fixed Foot Pedals
Front Floor Carpet Mats
With Carpet Floor Covering
Non Illuminated Sunvisor - Drivers
Non Illuminated Sunvisor-Passenger
With Level 3 Door Trim Panel
Running Boards - Platform
With Bright Front Grille
Less Exterior Wheel Lip Moulding
With Dipping Rear View Mirror
Telecsp TT Pwr Htd Lighted
With Black Exterior Mirror
With Driver Seat Back Map Pocket
Passenger Seat Back Map Pocket
Front Seat Armrest/Stowage
With Rear Under Seat Stowage Bin
With Front 4 Way Headrest
Less Rear Seat Centre Armrest
With Drivers Manual Lumbar Support
Less Passenger Seat Lumbar Support
Less Multi - Contour Seats
Less Temp Control Driver Seat
Less Temp Control Passengers Seat
Less Rear Heated Seat
2 Row-H/Ser Flip Up W/Elon Cushion
With Driver 2 Way Mnl. Seat Adjust
With Pass 2 Way Manual Seat Adjust
Trailer Tow Prep Pack
With Trailer Towing Attachments
Less Fifth Wheel
With Front Towing Hook
With Trailer Sway Control (TSC)
Less Fifth Wheel Hitch Kit
Cleat Tie-Down Kit B
Exterior Door Handle - Black
Lift/Bootlid Handle Exterior-Black
Less Remote Controlled Tailgate Rel
Frequency - 315MHZ
With Central Locking System
Door Entry R/Cont Unit - 2 Keys
Less Keyless Entry System
With Variable Intermittent Windscreen Wiper
Less Sun Roof
Less Tu-Tone Accent Colour
Less Body Tu-Tone Paint
Front Bumper - Steel Chromed
Rear Bumper - Steel Step - Chromed
With Front Licence Plate Bracket
Side Air Bag - 1st & 2nd row
Less Rear Seat Belts
Adjustable'D'Ring-Drivers Seat Belt
With Passenger Air Bag Deactivation
With Adjustable 'D' Ring Pass Seat
With Frame Mounted Tyre Carrier
Less Chassis Frame Extension Pack
With Conventional Spare Wheel
Tyre Pressure Sensors - 315 MHZ
Std Duty Dual Front Shock Absober
With Standard Rear Shock Absorbers
With Double Rear Wheels
6.5 X 17 Steel Wheel
Less Wheel Covers
Less Hub Covers
Non Locking Lug Nuts
With Standard Engine Cooling System
Less Engine Idle Shutdown Timer
Less Immersion Heater
Less Remote Starter
With Monobeam Suspension - Narrow
Less Stabilizer Package
Less Attitude/Ride Height Pack
With Standard Duty Front Suspension
With Front Stabilizer Bar
Single Leaf Rear Auxiliary Spring
With Rear Stablizer Bar
Less Rear Axle Package
3.55
Less Rear Axle Limited Slip Diff
Less Exhaust Pipe Extension
With 4 Wheel Disc Brake Hydro-Boost
Integrated Brake Control
4 Wheel Anti-Lock Braking System
Roll Stability Control Brk W/Betc
Normal Fuel Fill
Less Tracking System - FIA
Less Transmission Power Take Off
Man Transfer Case And Man Hubs
Less Skid Plates
With Mid-Ship Fuel Tank
Fuel Cap - Non Locking Green
With Diesel Fuel Capability
Less Gaseous Prep Pack
With Low Sulfur Diesel Fuel Content
Power Steering Gear
With Man Rake/Col Shift Strg Column
Standard PUR Steering Wheel
Less Heated Steering Wheel
Less Electronic Speed Limitation
With Speed Control
Less Auxiliary Heater
With MPH/KMH Speedometer
Tyre Inflation Monitor
With Compass Display
MFD High TFT Screen
Less Navigation System
Customer Info Display-Package 2
Less Lane Departure Warning System
Less Reverse Proximity Sensor
Less Blind Spot Information System
With Perimeter Anti-Theft
With Safeguard Anti-Theft Sys(Pats)
Heavy Duty Battery
Heavy Duty Alternator
Less Power Convertor
With AM/FM CD Player
With NAAO Radio Frequency
Satellite Digital Broadcast
With 7 Speakers
With Media Gateway Module
Less Garage Door Opener
Less Auxillary Lights
With Halogen Headlamp
Daytime Running Lamps Level 2
Headlamps - U.S. Symmetry
Less Front Fog Lamps
Less Spot Light
Roof Marker/Clearance Lights-Conv
Less Right Hand Spot Light
Less Lighting Packages
Less Interior Light Group
Tail lamps - Level 1
With High Mounted Stop Lamp
350 Series
F250/350/450/550 Super Duty
Primary Features
Version: 350 Series
Axle Ratio: 3.55
Territory: (+)"USA"
Minor Features
Less Rear Mudflaps
Less Front Fenders
Less Front Mudflaps
Less Bed Ramps
XLT
Pickup
14,000 LB. GVW
Less Memory Package
Brand Owner - Ford
With Privacy Glass
Less Floor Mat Kit
Fixed Foot Pedals
Less Fifth Wheel
Frequency - 315MHZ
Less Sun Roof
Less Wheel Covers
Less Hub Covers
Less Remote Starter
3.55
Normal Fuel Fill
Less Skid Plates
Power Steering Gear
With Speed Control
MFD High TFT Screen
Heavy Duty Battery
With 7 Speakers
Less Spot Light
350 Series
MarkBowers
09-24-2020 09:31 PM
Kimba
1999 to 2016 Super Duty
21
04-20-2007 09:13 AM
