V10 in an RV - Ford Truck Enthusiasts Forums
Modular V10 (6.8l)
V10 in an RV
Old 11-18-2017, 08:18 AM
gccch
gccch is offline
gccch is starting off with a positive reputation.
V10 in an RV
Hi all,
I have a new to us 2010 Winnebago with the V10. It has low miles, so I am wondering if I should be pro-active and replace the manifold studs now rather than later. They are fairly easy to access in the truck frame, but I don't want to open a can of worms either. They do look a little rusty, have not failed yet, but with now 16k miles on the engine maybe easier to get them out now? Here are some pics from one side. Can I replace one at a time without removing the manifold and replacing the gasket?
Old 11-18-2017, 08:25 PM
billybobofkf
billybobofkf is offline
billybobofkf is starting off with a positive reputation.
I think you should be prepared to open a can of worms. Lots of great posts in the history of this page on replacing broken studs. I would go for it.
Old 11-18-2017, 09:29 PM
rvpuller's Avatar
rvpuller
rvpuller is online now
rvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud of
If it isn't broke why try and fix it, I had 2 V10s one still had the original studs at 300+ when it died (I no longer owned it at that mileage) and the other had 130K when I traded it with original studs.
Denny
Old 11-19-2017, 09:06 AM
gccch
gccch is offline
Denny
Well I'm thinking it may be easier now to get them out before they continue to rust and degrade. If it doesn't matter and will be just as bad now then I will leave them alone.
Old 11-19-2017, 04:09 PM
rvpuller's Avatar
rvpuller
The only place you will see rust is where you can see them, when I changed the bad manifold gasket on my 4.6 F150 with 122K miles the stud where it went into the head was not rusted just the nut and exposed stud. I even reused 6 of the 8 studs, two broke off when trying to remove the nuts. Every motor I have ever taken apart had rusty exhausts studs. If you change them they will look the same way in a couple of years.
Denny
Old 11-20-2017, 05:11 PM
Diamnd1's Avatar
Diamnd1
Diamnd1 is offline
Diamnd1 is gaining momentum as a positive member of FTE.Diamnd1 is gaining momentum as a positive member of FTE.
Don't play pinata with a hornets nest if you aren't prepared to get stung!
Old 11-22-2017, 11:52 AM
geekwithoutacause
geekwithoutacause is offline
geekwithoutacause is starting off with a positive reputation.
Don't do it !
Some are guaranteed to break off.
Old 11-23-2017, 05:13 AM
Im50fast's Avatar
Im50fast
Im50fast is offline
Nice guy!
Im50fast has a great reputation on FTE.Im50fast has a great reputation on FTE.Im50fast has a great reputation on FTE.Im50fast has a great reputation on FTE.Im50fast has a great reputation on FTE.
I offer you mixed advice.
1. DONT WORRY ABOUT IT ! I got my v10 E350 4y5m ago and it already had some broken studs on the passenger side. It made some ticking noises when cold but only for 30-45 seconds or so. I’m a very busy man so I just ignored it.
Here I am 210,000 miles later with the same van and never fixed it. And yeah it probably has a few more studs missing or loose. I still drive it.
2. JUMP IN ! In your RV, I assume you have more room to work on it. And I assume it wouldn’t be a terrible thing if the project whooped you and caused days or weeks of downtime.
Soak them with PB Blaster a few times and then get into the job. Be sure to spend a few hours here on FTE learning what others have learned (learnt? Lol) before you.
Keep us posted.
Old 11-27-2017, 02:52 PM
sddesigns's Avatar
sddesigns
sddesigns is online now
sddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputation
I did play with the hornets nest deciding to fix the slight ticking sound and go with a new exhaust manifold since we were fixing the already broken ones, but now it doesn't have the Ford studs just the SS bolts that came with the Gibson headers.
Heres my story...https://www.ford-trucks.com/forums/1...d-project.html
Old 01-07-2019, 09:17 PM
PirateGhost
PirateGhost is offline
PirateGhost is starting off with a positive reputation.
Did you change those studs?
Old 01-08-2019, 07:48 AM
tiffy2000
tiffy2000 is offline
tiffy2000 is starting off with a positive reputation.
exhaust
Any concerns about drilling out the SS bolts for the headers if they ever break off ?
Rockwell
1999 to 2016 Super Duty
Today 08:30 AM
FTE Ken
Modular V10 (6.8l)
45
12-02-2002 09:09 PM
FTE Ken
57
11-14-2002 10:56 PM
FTE Ken
10-13-2002 09:43 PM
FTE Ken
Computer Chips & Tuners
09-25-2002 09:44 AM
Quick Reply: V10 in an RV
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
