High milage oil change questions
I never thought I would be asking about oil and filter types ,
but better safe than sorry with what is all new to me ; " modern
engines " , I have a 2006 f 150 with the 4.6 2 valve , it has just
under 170,000 miles on it , last oil change I used SAE 5 W - 30
and a napa gold filter , now its time to change the oil and want
to make sure that the oil/ filter combo is ok or should I use a
different filter , I think I'm ok to go with a 5W-30 oil .
I own lots of those exact engines in my police crown vics. I personally like 5w-30 after 150k miles, but you could also use 5w-20 as well. 5w-20 thru 10w-30 is the range you can use on these engines.
Also avoid the high miles oils, they just drain your wallet! You will find even todays cheap oil are super good quality.
I have used the motorcraft filter and oil (5W20) since day one. Cannot say I have had any issues, and been pleased with the oil changes. Just turned 132,000 on my 06 5.4. Was going to switch brands after warranty was up, but the motorcraft prices are decent and readily available at Walmart around here.
5W 30 will put more tension on the cam chains at cold start until full warm up occurs.
This causes excess wear on the chain guides.
If you were to run an oil pressure gauge, this would be seen as higher pressure for a longer period of time as opposed to 5w20.
My 4.6 is now at 276,000. Motor runs as new.
Good luck.
Good luck.
WatsonR
12-12-2017 07:44 PM
Milwaukee1979F150
21
04-17-2008 10:28 AM
