92 460 project....till it isn't
Old 11-17-2017, 03:05 PM
humphrey169's Avatar
humphrey169
humphrey169 is offline
Hey guys. I bought a truck a few years back. Probably 6 years ago. I bought it for body parts. 92 crew cab dually 460 auto 2wd. It had been setting for years before I got it. It had been parked because the rear axle went out. I took a trailer and an extra rear dually axle with me and my daughter and I went for a 3 hr road trip to get it. I son of the lady I got it from said he started it on starting fluid, I didn't try. We put the axle under it and winched it on the trailer and brought it home.
I found the fuel system from the tank to the injectors was full of solid gas residue. Replaced one tank and fuel pump with some I had left over. Blew the lines out and got some injectors from a friend of mine that has a mustang shop in Illinois. He knows gas stuff and I know diesel. He gave injectors from a supercharged mustang. It started and ran.
Drove it around a bit to see if the engine would be good for another project. Soon after it was making noise from the water pump. It had blue silicone oozing around the gaskets so I could tell it was changed but didn't know when. Engine seemed okay so I decided to put a pump on it. When I was putting it back together I cleaned all the blue off and used a small amount of black only around the water ports and torqued the bolts to spec. Went to start it and I heard a weird pop.
3 days I tried to start it. No fire. I checked this and I checked that. Finally pulled the cap off and cranked the engine and the rotor didn't spin. Turns out the pop was the timing chain breaking. When I tore back in to it i found the blue silicone from before had broke the blind holes in the chain cover and the broken pieces must have landed on the crank sprocket and when I cranked it it broke the chain. Sucks.
Not knowing about this site or anything about this engine I figured the valves probably hit the piston. I found some ported and polished heads from a guy at work. When I tore my engine down I found no indication of any contact with the pistons. New chain set and heads and distributor, plugs and wires and it was running again.
Old 11-17-2017, 03:28 PM
humphrey169
It sat for a year or better between breaking the chain and getting it back together. While I had the heads off I bought a kit from eBay to rebuild the injectors. All was good and it drove fine.
I pulled my toy truck to a truck this summer and it overheated. Puked all the tranny fluid out and I thought the ole truck was done. I didn't care about the engine or tranny because soon it will be replaced with a Cummins. But just for kicks I dropped the pan to check the filter. 164,000 mile on it so I expected some junk in the pan. Spotless. It must have been rebuilt at some point. New filter and fluid. I put in a new radiator since I will reuse it for the Cummins. Ran it down the road and shifted fine.
Now the problem I'm having now is it recently developed a stumble. Slight shake at idle and noticeable studded at speed. The test light to plug wire test has me puzzled. It changes the idle with all 8 plugs but not the same. Some almost kill the engine and other(mainly 2) slightly change it. Plugs all look good with make me lean toward an injector issue. My question is did I put in the wrong injectors from the get go. Can you tell by the color on the bodies? These are grey I think...I'm color blind, could be green or pink. I think the original color was yellow I think. Gave them to my buddy years ago and he quit work. I don't want to put much money in to it but would like to drive it. It's a cool truck after all. Here's the injectors and the day we brought it home
Old 01-27-2018, 05:10 PM
humphrey169
Ok so, I loaned this old truck out to my stepdad since his Cummins crapped out another injection pump. The miss had been bad enough that I parked it but now it had to be driven. I filled the tank with b12 injector cleaner before I parked it. I asked my step dad if the miss was any better and he said" yeah it runs great". I thought cool deal must have fixed it's self. Not the case. The plates ran out at the end on December but I had been working 7 12's pretty much since November and didn't get to it till the 2nd week of January. I went to go get it inspected and it would barely do the speed limit. Running on 5 cylinders. When I talked to my stepdad he said that it always ran like that. Turns out the injectors were clogged. I got some factory 460 ones from a buddy and it's smooth running again. Here's the ones I took out and the ones that replaced them
Old 08-10-2018, 10:27 PM
humphrey169
I've been using this old truck more and more. Built a new trailer that weights in at 5150lbs and my toy truck weights right 9500lbs so I cross the scales at 21000lbs. The truck does ok but the 3:55's leave me wanting more so I found a disk brake dually axle with 4:10 and a limited slip diff for it. I'll work on getting it ready and installed in a few weeks, hopefully
Old 08-10-2018, 11:16 PM
collkid's Avatar
collkid
collkid is offline
Thing is awesome. Massive.
Old 08-11-2018, 02:07 AM
Dania Mayer's Avatar
Dania Mayer
Dania Mayer is offline
Subbed to this thread I'm really sorry, I don't have any actual input I'm just genuinely curious to see how this turns out, and I own a '92 460 as well so totally sticking around to try and learn something, <3
Old 10-29-2018, 05:27 PM
humphrey169
I got to play today.
. I got that dana 70 put under this old truck. 3:55s to 4:10s was a good move. Disk brakes seem to be a plus.
So the test drive didn't go so good. I lost a ujoint at about 30 mph and a quarter mile down road. Clip didn't seat I guess and spit the cup out. Luckily I had some super dooper zip ties and fixed it good enough to get home.
. There was some questions about the emergency brake cables. It was a simple fix. I moved the bracket on the frame a couple inches forward.
Old 10-30-2018, 08:24 PM
humphrey169
I'm having trouble loading pictures
Old 10-30-2018, 09:38 PM
humphrey169
Roadkill style!!
Old 01-20-2019, 10:45 AM
humphrey169
What do you boys know about the caterpillar 3126?
This project may have taken a new direction. I bought a bus!!
Old 02-04-2019, 10:25 AM
humphrey169
I've had my bus now for 4 days and have put 400 miles on it. 62mph top speed ,but what it lacks in speed it makes up for in coolness. The wife didn't talk to me for a week. Then I convinced her to take a ride with me to get ice cream, called everybody in the neighborhood and took a 40mile trip. She had fun and it worked out so now we're cool again. Shame to cut it up but it'll make a sweet 6 door chassis
Old 02-07-2019, 09:57 AM
collkid's Avatar
collkid
collkid is offline
You bought a bus!?
Old 02-08-2019, 10:20 AM
Andy Hawks's Avatar
Andy Hawks
Andy Hawks is offline
Not gonna lie - pretty excited to see what you do with this! Lots of surplus busses sitting around and they can't ALL be turned into tiny homes...
Old 03-08-2019, 10:04 PM
humphrey169
So here's an update,
I Took the bus in to get inspected and pretty much thought it would pass with flying colors since it was still being used at the local school district. Nope. It needed the kingpins replaced. This thing is pretty much the same chassis as a Kodiak c60 or c70. Mine is a c70. The c60 kingpins are like $220 and mine was more like $700. Everyone said that they are a real pain to change. Mine was really easy since they just fell out after an hour getting the lug nuts off just one side. They are toqureed to 450ft lbs.
Anyway after I got them changed out I went back and it passed inspection and I got plates for it.
. Then I celebrated with some 3 inch long lug nut covers!!
Old 03-08-2019, 10:10 PM
humphrey169
Next I built a huge custom hitch and hooked my trailer up and tried it out. Pulls forward sweet....backing not so much. Took like 15 tries to get it backed to the spot that it goes
Quick Reply: 92 460 project....till it isn't
