57 F100 project - big window
Old 11-17-2017, 06:01 AM
joes99
joes99 is offline
joes99 is starting off with a positive reputation.
I am in the process of replacing rusted floors at this time. The previous repair attempt was pop riveting new panels over and around existing rust along with lots of bondo. I found a 60 cab with better floors and cab mounts that I am going to swap. The plan is to make a modern driver with independent suspension
I have a 4.6 DOHC that I plan to use if I am successful in saving the cab along with the Mark viii rear.
Mine
Better
Old 11-17-2017, 10:16 AM
flhx06's Avatar
flhx06
flhx06 is offline
flhx06 is starting off with a positive reputation.
Nice work. More pictures of the project would be cool!
Old 11-17-2017, 10:36 AM
joes99
joes99 is offline
More pics
Bringing home
Ugly repair
Valance with parking light delete,
I mentioned bondo
Old 11-17-2018, 07:18 AM
joes99
joes99 is offline
Progress has been slow, the donor floor turned out to be better at the rear half.
I have the floor and steps repaired and ready to install. Working on the cab so I have something to attach the floors to.
patched sections of floors, steps and cab mounts
vent delete, bottom end repaired. I have a replacement for area cut out
Old 11-17-2018, 07:27 AM
joes99
joes99 is offline
drip rail
nice hole in the center of the roof too
rust everywhere I look
cut off driprail, added round rod. the plan is to duplicate the swoop above that makes the roof line
Old 11-19-2018, 08:20 AM
dman2008's Avatar
dman2008
dman2008 is offline
dman2008 is starting off with a positive reputation.
Nice work, my cab is rough too, just about to start repairing more of it. I'm building a 4.6 3V 5 spd with Thunderbird IRS, I will enjoy watching your build.
D
Old 11-19-2018, 10:33 AM
flhx06's Avatar
flhx06
flhx06 is offline
Great work on the fab! keep it going
Old 02-12-2019, 06:46 PM
joes99
joes99 is offline
More progress
New door bottom and lower corners
Removed cab vents awhile this was open
Cowl vent filled
Old 02-13-2019, 07:54 AM
G-Force junky's Avatar
G-Force junky
G-Force junky is offline
G-Force junky is starting off with a positive reputation.
I like seeing metal work progress. Nice work!
Old 02-13-2019, 04:50 PM
joes99
joes99 is offline
Thumbs up metal work
Cab corners purchased at Dennis Carpenter right after I bought the truck, excellent timing on my part
Filler neck filled
Old 02-13-2019, 08:48 PM
robski_1970
robski_1970 is online now
robski_1970 is starting off with a positive reputation.
Looks good! When did you get the cab corners? Did he start reproducing them again because they've been out of them since the mold die broke.
Old 02-14-2019, 12:04 AM
Fomoko1's Avatar
Fomoko1
Fomoko1 is offline
Fomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputationFomoko1 has a superb reputation
A major project that looking good, I`m glad you have way more skill than I do.
When did you buy the cab corners, lately or a long time ago?
Old 02-14-2019, 05:08 AM
joes99
joes99 is offline
Cab corners
I believe I bought them in 2016. I was at the Charlotte Auto Fair just down the road so I decided to go pick them up, glad I did it then. I also picked up a fender repair panel that I won't be using if someone needs one, right side.
Old 02-16-2019, 08:49 AM
flhx06's Avatar
flhx06
flhx06 is offline
Great progress. The bed looks like its in great shape from the one picture. Wish I had that!
Old 02-16-2019, 09:23 AM
joes99
joes99 is offline
Bed
The bed floor is shot but the sides are solid. My plan is to use a wood floor and replace the flat corner sections
manlikesford
01-18-2013 01:17 AM
guitarnik
18
12-10-2008 06:05 PM
Quick Reply: 57 F100 project - big window
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
