57 F100 project - big window
I am in the process of replacing rusted floors at this time. The previous repair attempt was pop riveting new panels over and around existing rust along with lots of bondo. I found a 60 cab with better floors and cab mounts that I am going to swap. The plan is to make a modern driver with independent suspension
I have a 4.6 DOHC that I plan to use if I am successful in saving the cab along with the Mark viii rear.
Mine
Better
Mine
Better
Progress has been slow, the donor floor turned out to be better at the rear half.
I have the floor and steps repaired and ready to install. Working on the cab so I have something to attach the floors to.
patched sections of floors, steps and cab mounts
vent delete, bottom end repaired. I have a replacement for area cut out
Received 1,353 Likes
on
