Leaking tank making a new one
Found out I'm losing diesal from the front tank so I thought about it why not make a big one and get rid of the dual tanks.... I know I can make this just wanted to know what it needs I know a return line, a line to the fuel pump, and a hole to put the fuel in I want to get rid of fuel selector...I'll be making it out of steel.... if I'm missing anything plz let me know lol one problem after the other lol I love my truck
IIRC, guys were installing 38 gallon Bronco tanks. Fuel Tank Rear 38 Gallon-Broncograveyard.com I can't remember if that was an IDI Van thing, or an IDI truck thing, but it was all the buzz on this forum a few years ago. I know when I looked into it for my IDI van, the frame rail wasn't tall enough to accommodate it, but maybe your truck can handle it. It would save you the time and effort of fabbing up tank on your own.
well I got the steel lol be cheaper for me to make one but just wanted a little knowledge about the tank I know the stock tank all of its lines are on top of it I thought it would be better to put the sendimg side on or close near bottom for it doesn' have to fight gravity and put the return side on top... would that work??
I personally would never put a sending unit or fuel pickup on the side or bottom of a steel diesel tank. Sounds like a perfect place for water to build up, cause rust, and eventually leak. now if you were working on an aluminum tank, that's different.
Fighting gravity is not a thing on these small scales. I think I read these lift pumps (and e-pumps) can pull diesel up a dozen feet in theory.
Also, you don't want your return splashing into the tank. It causes bubbles. On long roadtrips, you'll have aerated fuel. That's why there is a straw and restricter at the end of your stock fuel return, so that it dips into the fuel and doesn't allow the fuel to be peed into the tank.
If I were you, I would buy the bronco tank. Or a similar ford tank. it's going to be pressure tested and simple to install.. It already has the fuel nozzle bib, it has the stock fuel pickup/sender assembly with seal mount. It has the strap insets. It's a win-win-win scenario.
Whereas a homemade tank can work, but it'll take a decent amount of design, fab, and testing to verify it is constructed properly. And you'll always have the nagging feeling if it will last. Also, you will have to custom install your own fuel pickup, nozzle, and sender. Sounds like a lot of work. Especially if you have to service it in a few years, like most of these parts require.
"I wouldn't see why this wouldn't work."
But whatever, do the custom steel tank. it's your ride.
I can understand the desire to simplify the fuel system by going to one tank and eliminating the fuel select switch. However, as the others said fabricating your own tank is quite an undertaking. Why go through all the trouble when you can do the 38 gallon tank swap with parts that are readily available? Or, if you really want a new tank just buy an aftermarket one from Summit or Jegs. They only carry about a MILLION of them.
FWIW, you can get the 38 gallon tank from LMC Trucks too.
Truck Parts & Truck Accessories for Chevy, GMC, Ford & Dodge Trucks | LMCTruck.com
Yea I can doo a flip vent too and my lines inside of tank are going to be steel as well going to put a filter going to make it easy access just in case of maintenance... no rubber everything will be welded water tight and Imma do a pressure test on it since we have one at work ... I guess I could set up a heater by it or in it I could even put a pump in it.... but I like my duralift it does good
Not that it matters now, but they sell universal level senders. Might not work with the stock gauge, but you could install a fuel gauge to match. Or come up with a circuit to adapt the sender resistance to the gauge resistance.
If you want to make your life really easy, just buy a Centroid brand fuel sender. Super simple design and easy to install. Plus you can have them program the required Ford resistance so you can adapt it to your stock Ford fuel gauge. CENTROID PRODUCTS
However, like I and Olds86 have said, I highly recommend you just use the Bronco or Ford tanks. I've made my own fuel tanks and it's never just a quick thing and it's never cheaper.
