58 Sheetmetal gauge?
I don't know where you will be getting it from but you may no have a choice.
When I could get it thru a body supply store they only had I think it was 20 ga, it was thiner than what I was working on but did the job.
I moved down south and the body supply here can't get sheet metal.
They pointed me to a welder that might be able to get me sheets.
At that point I could see a mark up on the sheet so I am using some from my parts trucks scrapped body.
Dave - - - -
Dave - - - -
I have to take a close look but I think if I use the new cab, I will only need to repair the corners, one step and a small area on the passenger front pan. Much less work than the original cab. Will need to cut holes for the original AM radio but I'll lose the padded dash. Probably better anyway as I can cherry the dash but when I cut and weld fabric, it gets all messed up.
78_f800crewcab4x4, you still looking for a padded dash? If I decide to swap cabs, you get first dibs. What you got to trade?
