Leveling kit questions - Ford Truck Enthusiasts Forums
2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Old 11-14-2017, 07:58 PM
hollandc222 hollandc222 is offline
hollandc222 is starting off with a positive reputation.
My situation is I've got a new truck and I keep reading about a leaving kit 2.5 inch for front I keep looking at my truck and thinking if I raise it 2.5 inch in the front it would be rather high compared to the back if I do have a factory leaving kit installed will it have similar parts from factory as the ones from after market
Old 11-14-2017, 08:49 PM
jackjude24 jackjude24 is offline
jackjude24 is starting off with a positive reputation.
I have 6.2 also that I am going to level out here soon I was thinking maybe take it to a shop that installs leveling kits and get there opinion on what size to go I think anywhere from 1-2 inch you should be fine with just spacers 2.5 and above will probably mess with the streering and would probably also require a track bar relocation kit and that is when it will start to get pricey.
Old 11-14-2017, 09:20 PM
Super Duty STX's Avatar
Super Duty STX Super Duty STX is offline
Super Duty STX is starting off with a positive reputation.
I can't see for sure, but it looks fairly decent as-is so I am assuming it is a 250. Many of the guys, including myself, are using 2.5s on the 350s in order to keep a slight rake. 250s aren't quite as tall in the back so you might end up looking a little nose high unless you block, or airbag the rear.
Old 11-14-2017, 09:58 PM
I'm looking a a (ready lift 2.5") but I'm still thinking it looks level idk lol but the ready lift kit has it all like 250$ I've read a lot of good on them
Old 11-14-2017, 10:03 PM
I purchased the same kit as this thread https://www.ford-trucks.com/forums/1495678-low-budget-leveling-kit.html
Omega Man Omega Man is offline
Omega Man has a good reputation on FTE.Omega Man has a good reputation on FTE.
After quite a bit of research I've settled on this kit.
http://amzn.to/2ijiw6H
Going to install it this winter when work slows down.
Old 11-14-2017, 10:30 PM
Super-Truck Super-Truck is offline
Super-Truck is gaining momentum as a positive member of FTE.Super-Truck is gaining momentum as a positive member of FTE.
Quote:
250 and 350 have same rear blocks so thats not really true. I could see a 6.2 sitting higher since it doesnt have the powerstroke powerplant weighing it down as much much.
CBEllis's Avatar
CBEllis CBEllis is offline
CBEllis is starting off with a positive reputation.
Measure the truck first, at the center of the front wheel-well, then the back. It looks closer to level than my 250 was but, I had factory installed 3 blocks in the rear. It sat 3.5 lower in the front - a noticeable difference. I bought the 2.5 ReadyLift kit with the trac-bar bracket (you really need the bracket for alignment and castor angles). I like the way mine turned out. Now, gotta decide on 35s or 37s...
Old 11-14-2017, 10:34 PM
JHatley7 JHatley7 is offline
JHatley7 is starting off with a positive reputation.
Im running BDS 2" with Fox. Looks great 0 complaints. Also threw bags on out back.
Old 11-15-2017, 01:12 AM
Quote:
nice truck I'll measure tape on it when I get home I've done lots a looking at the tires my stock are 34x11 I was wanting to go with the 35x12.5 due to a few things bigest was tire weight not extremely higher than the 34 that might keep my MPG higher and it give it a little wider look 37 will also throw the speedometer off a good bit
Old 11-15-2017, 08:31 AM
jlfinch jlfinch is offline
jlfinch is starting off with a positive reputation.
I wanted to maintain a little rake and didn't want it to squat too bad with trailer, so I put 1" BDS blocks in front and am very happy with the way it sits now.
Old 11-15-2017, 09:38 AM
shortride's Avatar
shortride shortride is online now
shortride has a good reputation on FTE.shortride has a good reputation on FTE.
If you only want leveling your truck, consider replacing the stock rear spring spacers with a set of 2016 spring spacers (6C3Z-5598-A). This will lower the rear-end approx 1.5 inches and keep you from having to have the front-end realigned. You will be able to use the stock U-bolts. If you had rather have your truck sit higher in the front you will have to get an alignment after a front-end lift kit is installed.
Old 11-15-2017, 01:52 PM
willynilly willynilly is offline
willynilly is starting off with a positive reputation.
Quote:
looks sharp. im seeing alot of trucks that are supposedly level but to me they almost look sqautting without any weight. hookup a trailer and your nose is 4" in the air. seen one yesterday like that. looked almost 1" nose high without a ounce of weight in the bed
Old 11-15-2017, 04:29 PM
Quote:
wife sent another pic today when it was on for sure level ground looks level to me
Old 11-15-2017, 07:48 PM
cficare cficare is online now
cficare has a good reputation on FTE.cficare has a good reputation on FTE.
Quote:
This is what I'm also doing. This is the quick-n-easy route if you're not looking to install larger tires. Uses all Ford parts ... no front-end geomtry changes ... and can be done for less than $100. Here's a link to another thread on lowering the **** end ... https://www.ford-trucks.com/forums/1...-rear-end.html
2010 F150 2.5 inch leveling kit cbrewer15 2009 - 2014 F150 1 11-16-2017 11:45 PM
is a 2.5 inch leveling kit too much fordtruck1336 2009 - 2014 F150 6 09-14-2017 10:54 PM
Looking to swap Carli 4.5" kit for your 2.5" kit Slowlearner Ford Truck Parts for Sale 0 02-17-2017 07:07 AM
4 inch lift Black15F250 Ford Truck Parts for Sale 0 08-03-2016 10:57 AM
4 inch lift kit Black15F250 All Other Items for Sale 0 08-03-2016 09:17 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
