Could have been worse...still sucks
BODY WORK HELP NEEDED.......my truck rolled forward off of the wooden blocks the wheels were on. The blocks rolled the rear of my front fenders inward. No creases on the flat part of the fender. Slight creases on the undernearh (flange) part of the fender. What I call the flange is the bottom of the fender that was rolled under by the factory for looks and strength. I can pull the fenders out but they spring back to there bent position. I tried to find what I would call a HOMEMADE SPREADER BAR to force the fender past it's starting point. All searches for SPREADER BARS led me to canvas stretchers. I tried to take photos but the damage doesn't show up. Any help with tools and/or technique would be appreciated. Thanks
Here is what I did once. 1" plumbing pipe with 1/2" threaded stock inside. Couple of 1/2" nuts to keep the threaded stock sticking out of the pipe. Some sort of cushion between the end of the threaded stock and your crunched fender, like a small padded 2/4. Brace the pipe against something and start slowly working the nuts to extend the threaded stock out of the pipe and making it push against the padded fender crunch. Sorry no pictures.
I fashioned a SPREADER BAR based on Ranger Pats concept. Word of caution....if you search SPREADER BAR on Utube you will get a lesson on S&M. Pushing the fender past it's pre-bent location but it's still returns to the bent position. There are no obvious creases or dents to hammer and dolly. Do I need to add some heat to the equation? Damage to paint is no worry in this trucks condition. I will try to get pics tomorrow with the tires off and the SPREADER in place.
https://www.harborfreight.com/4-ton-...kit-62115.html
This may be what you are looking for...
on
You will definitely need to push it well beyond the straight but as you are not concerned with paint you can lightly tap the area around the bend with a body hammer after pushing it well past the straight point this will help " set " the metal . I very often put masking tape on my hammers to lessen the paint damage .
hilltd69
02-23-2008 04:59 PM
