Solving Suspension Issues While Towing and Hauling
Airbags, aftermarket shocks and add-on springs are common suspension upgrades for towing your travel trailer or hauling heavy loads in the back of your pick up. But in many cases they are not the most appropriate or cost-effective solution to unlocking the true towing/hauling capacity of your truck. There’s a smarter, easier way to enhance the suspension of your rig to handle any outdoor excursion.
Torklift International offers the StableLoad suspension upgrade to correct side-to-side sway, body roll, reduce stopping distance and sag when towing or hauling.
“The key to the StableLoad is it can solve all of the suspension issues you might run into while towing and hauling, all on its own,” said Torklift International President Jack Kay. “The driver will also find that they are not encountering any of the negative side effects associated with other aftermarket suspension add-ons such as a stiff ride or increased sway and body roll.”
StableLoad dramatically improves your vehicles handling characteristics by “pre-loading” the factory overload springs to prevent the sag that would normally activate them. In effect, StableLoad simply locks your rear leaf springs into performing under load the way your vehicle engineers designed them to.
The StableLoad Quick Disconnect engages and disengage your overload springs in just a few seconds. Engage the StableLoads to haul your truck camper or fifth-wheel trailer on the way to the campsite. Disengage them by removing a draw pin once you’re settled to return your vehicle to its soft stock ride with ease.
Before outfitting your truck with more costly and elaborate suspension add-ons that can permanently alter ride quality, consider the StableLoad as the most affordable, effective, and simplistic solution.
Available at Torklift, StableLoad is backed by a lifetime warranty that is also extended to the factory overloads on your vehicle.
If you’re interested in purchasing the StableLoad suspension upgrade kit from Torklift, click here to visit one of our Certified Dealers near you. To contact us for more information, reach us at support@torklift.com or call our tech support at 800-246-8132. We are more than happy to help keep you protected this winter.
__________________
Torklift International – Towing, Suspension, Tie Downs, Steps
Call me direct: 1-800-246-8132
Visit our Blog: http://www.torklift.com/blog
Torklift Sheryl
Vendor Specials, Discounts, Product Announcements & Group Buys
04-23-2019 06:43 PM
Torklift Sheryl
04-05-2018 03:07 PM
Torklift Sheryl
06-02-2016 07:48 PM
Torklift Sheryl
08-18-2015 11:49 PM
