Two issues
Two issues
first issue - the odometer on my 2001 F150 Lariat just goes out. It still works but goes out as if it has a loose connection (the numbers are not lit up).
second issue - I want to pull out the honeycomb grill insert and repaint it. The color it is now is like a faded gray, curious as to what the actual color was when it was new? Is there an easy way to pull out the insert?
BIGBAMA#(
22
07-08-2007 05:15 PM
