Water on passenger floor after rain - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 11-13-2017, 09:22 AM
Bronxguinea's Avatar
Bronxguinea Bronxguinea is offline
Bronxguinea is starting off with a positive reputation.
I have a 2001 Ranger extend a cab Edge and after it rains I get water on the passenger floor ,I cleaned out the drains under the windshield cowl. still leaks but I did notice a couple of rubber pieces came out when I clean the drain out. has anyone else come across the same thing and resolve this issue ?
Old 11-13-2017, 12:36 PM
reddog99 reddog99 is offline
reddog99 is starting off with a positive reputation.
I don't know what the items in the photo are, but many Rangers develop a leak around the weatherstrip on the rear tail light on top of the cab.
Old 11-13-2017, 07:47 PM
New LED light and gasket not coming from there .It's coming from the cowling
Old 11-14-2017, 09:34 PM
MikeB 88's Avatar
MikeB 88 MikeB 88 is offline
MikeB 88 is gaining momentum as a positive member of FTE.
In my case I had many little cracks in the windshield under the trim. Found them when I went to the glass store to see about resealing the windshield..
Don' know where the previous owner had the windshield replaced, but there were gaps in the sealant.
Old 11-14-2017, 11:27 PM
I use a hose on sprinkle ,and it only leaks when it goes in the cowl holes , has to be gasket from the a/c unit
Water leak under dash on passenger side 1993 ford Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 12 05-12-2017 02:40 PM
Still leaking water 1993 ford Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 0 05-06-2017 02:48 PM
Rain entering through ventilation Cyrusjohn 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 16 04-09-2017 08:58 AM
Water leak causing power liftgate to open itself and set off alarm Stevem8 2007 - 2014 Expedition & Navigator 12 02-10-2017 08:07 AM
Water on the floor! Branjo 1967 - 1972 F-100 & Larger F-Series Trucks 18 11-23-2016 09:06 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
