2wd lift kit - Ford Truck Enthusiasts Forums
2wd lift kit
Old 11-12-2017, 09:22 PM
SuperDutyScaler's Avatar
SuperDutyScaler SuperDutyScaler is offline
SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.SuperDutyScaler has a great reputation on FTE.
2wd lift kit
Even though it's my work truck I need this thing higher off the ground. Smashed the lower valence today going into a new job site on uneven ground. Plus u can't even get under the truck to change oil etc...i don't need it like my f350 but a few inches would be nice. I found this on eBay and if like to buy it, and issues with these kits with front end wear etc?
https://m.ebay.com/itm/1997-2003-F-150-2WD-Front-3-Rear-2-5-Steel-Complete-Lift-Kit/182223409519?fits=Year%3A2001%7CModel%3AF-150&hash=item2a6d5c916f:g:1WAAAOSw241YlMik
Old 11-12-2017, 09:23 PM
Old 11-12-2017, 11:05 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
You can get an idea of what it looks like by putting a jack under the front end and pushing the body/ frame up 3 inches. Note that the tires rotate out at the top and would cause excess wear......... you just need a front end alignment after the kit is installed.
Old 11-13-2017, 08:16 PM
Reading online I've found that I shouldn't go more than a 2" level kit? If not I'll have to buy adjustable upper control arms?
Then I see a 2" level puck isn't 2" it's more like 1 1/4" of actual lift, and a 2.5" is like 1 3/4"...?
Old 11-14-2017, 09:18 PM
kd4gij's Avatar
kd4gij kd4gij is offline
kd4gij is starting off with a positive reputation.
If I was going to lift my 2wd. I would go with a 3" spindle lift in the front and what ever blocks for the rear to level it. That way the rest of the front end stays the same. Of Corse you will need an alignment.
Old 11-15-2017, 09:37 PM
mdr617's Avatar
mdr617 mdr617 is offline
mdr617 is starting off with a positive reputation.
Post
I used the Daystar leveling spacers up front for about $30 and installed them myself along with HD coils and Monroe reflex shocks. Rear just has Monroe load adjusting shocks.
Truck looks and drives good, I'm happy with the set-up. Of course you will need an alignment after doing nearly any suspension/steering work.
Old 11-16-2017, 02:32 PM
Kbc219 Kbc219 is offline
Kbc219 is starting off with a positive reputation.
I'm lifting my 2wd 04 f250 super duty 5.4l v8. But I can't find anyone who sells extended brake lines for 2wd, they are all 4wd. Is there any difference? Or can someone please point me in the right direction?
Old 11-16-2017, 02:33 PM
Lifting a 2wd? Rjustinpalmer 2017+ Super Duty 9 03-19-2017 01:17 PM
Anyone try Doetsch Tech Shocks? young_bucka 2009 - 2014 F150 2 02-13-2017 08:28 AM
86 f350 2wd lift kit help! TheBlackBeast86 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 03-15-2016 09:25 PM
Just got a 1998 Ford Expedition and a have a few questions Seven11 1997-2006 Expedition & Navigator 1 02-09-2016 03:25 PM
Leveling Kit on '89 F-250 2WD ??????? CrispyWafer Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 6 12-17-2015 07:09 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
