rear wheel center caps (on front) - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > 2017+ Super Duty
Reload this Page >
2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Old 11-10-2017, 06:34 PM
bushpilot
bushpilot is offline
bushpilot has a great reputation on FTE.bushpilot has a great reputation on FTE.bushpilot has a great reputation on FTE.bushpilot has a great reputation on FTE.
Who did the rear center/axle covers on the front?
I'm looking for the part number / cost.
I RARELY manually lock the front hubs - and have been giving thought to covering them up with rear center caps.
Old 11-10-2017, 07:58 PM
cficare's Avatar
cficare
cficare is offline
cficare has a good reputation on FTE.cficare has a good reputation on FTE.
I did it on my King Ranch but you don't mention which trim level you have ... and yes, that does matter. Pull one of your rear hubcaps and see if you can retrieve a part number from inside. I paid about $35 each via fleabay, but a local dealer may be less.
Old 11-10-2017, 08:16 PM
bushpilot
Thanks. Mine's a Platinum.
Old 11-10-2017, 08:39 PM
ChrisGTA
ChrisGTA is offline
ChrisGTA is starting off with a positive reputation.
"Dealer might be cheaper". That's funny right there.
Old 11-10-2017, 08:45 PM
cficare's Avatar
cficare
cficare is offline
Laugh if you want, but I have found the dealer to be less expensive than the same new item on ebay on many occasions ... not always, but many. Ebay ain't the bargain house it once was.
Old 11-10-2017, 09:02 PM
First Dually
First Dually is offline
First Dually is gaining momentum as a positive member of FTE.First Dually is gaining momentum as a positive member of FTE.
Same goes for Amazon, but not as often as eBay. It used to be it was almost always a safe bet those 2 companies had some of the better values to be found. Now, not so much. On occasion, they have an absolute ripoff.
In their defense, the return policies have treated me right. I don't milk the system, but will request a return or refund when I believe it is reasonable. Neither company or their sellers have rejected a request.
Old 11-10-2017, 10:43 PM
ChrisGTA
ChrisGTA is offline
I agree eBay isn't necessarily cheap. My comment was aimed at the notion that the dealer might be cheap. That cap will be over a hundred bucks from the dealership.
Old 11-11-2017, 06:53 AM
cficare's Avatar
cficare
cficare is offline
If we're lucky, "bushpilot" will report back with what he found during his shopping.
Old 11-11-2017, 07:22 AM
bushpilot
mine look similar to p/n 1130E.
on EDIT - the 1130E is the REAR cover (It has more depth than the front cover)
Old 11-11-2017, 07:27 AM
bushpilot
The 1130G is the FRONT cover
Old 11-11-2017, 07:37 AM
Poncho450's Avatar
Poncho450
Poncho450 is offline
Poncho450 is gaining momentum as a positive member of FTE.Poncho450 is gaining momentum as a positive member of FTE.
I'd check with Fairway Ford in Ohio or Banner in Louisiana if you don't find what you want elsewhere.
I think they both have an ebay presence as well as buying directly from them online.
Just a couple of days ago had an Amazon package arrive with one item in it. There were supposed to be 3. Contacted them and in less than an hour the refund process was in motion. 2 days later my card was credited.
The few occasions I've had to use customer service with them have had good outcomes.
Old 11-11-2017, 07:40 AM
cficare's Avatar
cficare
cficare is offline
Does THIS ONE look right to you? Part number: HC3C-1A096-GD
Found another PN: HC3C-1A096-GBD
Old 11-11-2017, 09:41 AM
bushpilot
That looks the same as mine...
Just pulled my cover the P/N inside mine says HC3C-1A096-GBD
apparently the center disk/logo can be had/changed w/out buying the entire cover.
Old 11-11-2017, 09:50 AM
bushpilot
HC3C-1A096-GD is a less deep (more shallow?) cover -
than my HC3C-1A096-GBD
Old 11-11-2017, 10:03 AM
bushpilot
The Shallow HC3C-1A096-GD is the FRONT cover.
Front vs Rear covers<br/>HC3C-1A096-GD & HC3C-1A096-GBD
Front On (rear on ground)<br/>
Rear Cover on Front Wheel
Quick Reply: rear wheel center caps (on front)
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
