I believe the image directly above your post shows he already has the deeper covers for the rear axle.
as you know thats correct
you'd have thought the number of pictures would enable people to see the difference - but then i guess if you don't read the thread they can't see that.
The extra rear hubcaps I bought for my KR were slightly deeper than those that came on my rear axle. The difference is so slight, I will be amazed if anyone notices. So unless you're OCD about them, either depth will look good. FWIW, I installed the deeper caps up front.
I'd check with Fairway Ford in Ohio or Banner in Louisiana if you don't find what you want elsewhere.
I think they both have an ebay presence as well as buying directly from them online.
Just a couple of days ago had an Amazon package arrive with one item in it. There were supposed to be 3. Contacted them and in less than an hour the refund process was in motion. 2 days later my card was credited.
The few occasions I've had to use customer service with them have had good outcomes.
Mr. Bezos (CEO of Amazon) made a point of publicly disparaging my political point of view. Not to mention that he hired that (in my opinion) lying little commie Jay Carney. Amazon doesn't get a dime from me, anymore.
were you just trying to add the center logo to the front cap?
or change the center logo on rear caps?
the logo's center pieces won't fit on the front caps because theres no place for them to "clip" into.
I’m just trying to add the center logo to the front cap. Does it not clip into the same place as the 1130K piece? Or am I completely wrong and the front cap is just one solid part with no place to clip anything into?
Actually My wheel is different than yours. I don’t have hubcaps, just the center pieces. My truck is also a platinum. Guess I assumed all platinums had the same wheels. Rear Front (Yes it’s mounted on the rear axle, whoever did my tire rotation didn’t seem to care)
I must have the 20 x 8.5 (alum polished) 1007F
I assume you have either the 1007B or 1007D wheels
Agree. Mine is a F250, yours is a F350. I googled around a bit and I see my style wheel on the 250 platinums, and your style on most of the 350 platinums.
I have found a new life for a trampoline spring tool. It is excellent for removing the caps.
I want to see a photo of that. In the meantime, here's a photo of a tool I made. Slip the OEM lug wrench through the loop, hook this tool into the relief in the hubcap, then easily pry the cap off leveraging the lugwrench against the tire's sidewall.
