Injector rebuild Yellow Submarine.
Old 11-10-2017, 02:54 PM
Royson12's Avatar
Royson12
Royson12 is offline
Royson12 is starting off with a positive reputation.
Ok, got my parts from 406 injectors. fixin to pull my drivers bank of injectors. going to start with those first. I also ordered Dummy and tube seals. They should be here tomorrow. Built a fixture to hold them in for dissasembly. fixture.little diferent from my drawing. My macinist buddy said I over engineer! I tend to do that. lol. This one will work fine. Any boddy want any pics of how its made, let me know. And, any of you nay sayers, warning against me rebuilding my own injectors, dont waste your time. My hat is set, and pointed in that direction. I want to do it myself. Any suggestions of what else i might look into resealing while I'm in there, please advise. I will take as many pics as I can along the way. (of the injector rebuild). Any advice would be appreciated. (This side of leave it to the pros!) lol
Old 11-10-2017, 03:16 PM
Royson12's Avatar
Royson12
Royson12 is offline
Test pigeon!
Old 11-10-2017, 03:20 PM
Royson12's Avatar
Royson12
Royson12 is offline
Worked off the copper washer with a utility knife. By the way, most of this I learned from the internet.
Old 11-10-2017, 03:27 PM
Royson12's Avatar
Royson12
Royson12 is offline
27mm Deep socket. Be carefull and dont beat up your nozzle with the ratchet. Get a deeper socket.
Old 11-10-2017, 03:33 PM
Royson12's Avatar
Royson12
Royson12 is offline
now the innards.
Old 11-10-2017, 03:36 PM
Royson12's Avatar
Royson12
Royson12 is offline
Now the topside.
Old 11-10-2017, 03:40 PM
Royson12's Avatar
Royson12
Royson12 is offline
Carefully remove the wiring clip.
Old 11-10-2017, 03:49 PM
Royson12's Avatar
Royson12
Royson12 is offline
Remove this doohicky with a 4mm socket and a t10 torx.
Old 11-10-2017, 03:50 PM
wedge542's Avatar
wedge542
wedge542 is offline
wedge542 is gaining momentum as a positive member of FTE.
Are you just trying to save a few dollars why your building your own or just need the challenge and curious to see if you can do it? That fixture tool tells me you done some homework.
Old 11-10-2017, 03:53 PM
Royson12's Avatar
Royson12
Royson12 is offline
Take real good photo noted of the orientation of all the parts during dissasembly.
Old 11-10-2017, 03:55 PM
Royson12's Avatar
Royson12
Royson12 is offline
One more pic to note the orientation of the spool valve vs. thr alignment notch on the bottom half. before final dissasembly.
Old 11-10-2017, 03:56 PM
Royson12's Avatar
Royson12
Royson12 is offline
Removed the coils. I will ohm them out later, before reassembly.
Old 11-10-2017, 03:58 PM
Royson12's Avatar
Royson12
Royson12 is offline
Note orientation of spool.
Old 11-10-2017, 04:19 PM
Royson12's Avatar
Royson12
Royson12 is offline
t15 to remove the spool body.
Old 11-10-2017, 04:22 PM
Royson12's Avatar
Royson12
Royson12 is offline
Dissasembly complete. Now to remove my injectors, and do the real deal!
Quick Reply: Injector rebuild Yellow Submarine.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
