Intermittent Pilot bearing Noise?
Old 11-09-2017, 03:03 PM
ZSK's Avatar
ZSK
ZSK is offline
ZSK has a very good reputation on FTE.ZSK has a very good reputation on FTE.ZSK has a very good reputation on FTE.
It's a very short clip and a few years old but you can here the noise just after startup. I've watched a few youtube videos about bad pilot bearings and to me, it sounds very similar. The noise occurs at idle and just above idle. In gear or neutral, with the clutch in or out. I don't believe it is front end related alternator, fan, etc. but rather rear of the engine or front of the transmission. Trans is a T98 for reference. Any thoughts?
Old 11-09-2017, 10:16 PM
jcslocum
jcslocum is offline
jcslocum is gaining momentum as a positive member of FTE.
In gear, clutch out and you have a noise?
in this situation the pilot bearing will not be turning. Can you confirm?
Old 11-12-2017, 11:32 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Exclamation Intermittent THROWOUT bearing noise.
The noise is coming from the throwout bearing, not the pilot bearing.
The throwout bearing (C0TZ-7580-A) is pressed onto a collar (B3TZ-7561-A) that originally had a Zerk (grease) fitting on it.
It's possible that a previous owner replaced the collar with one that didn't have a Zerk fitting.
Or it's present, but hasn't been greased in many years, because some people in "today's world" are unaware of it.
When Ford introduced "Lifetime Lubrication" in 1963, rubber plugs were placed in the Zerk holes, but by the mid 1970's, FoMoCo replacement parts had no provisions for Zerks.
The pilot bearing is bronze, so it was never greased.
Old 11-12-2017, 02:34 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
ALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputation
I haven't ever seen a zerk on the trucks' release bearing hubs. The release bearings are sealed, I don't know how you could get grease into them. I have heard of the guys with '30's and early '40's cars greasing them, so it could be a late-40's change. No mention of a grease point in the workshop manual. Replacing the release bearing isn't hard but requires trans removal.
Ninetynine7.3
03-02-2015 09:37 AM
Aus56
11-20-2014 05:34 PM
matt2491
06-22-2008 05:29 PM
Alvin in AZ
08-17-2006 06:43 PM
BigJake86
10-30-2004 07:15 PM
Quick Reply: Intermittent Pilot bearing Noise?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
