2008 Ford E250 4.6V8 Water leak PLEASE HELP - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Ford Vans and other vehicles > 1968-2013 Full Size Vans
Reload this Page >
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 11-09-2017, 02:36 PM
Winstonx
Winstonx is offline
Winstonx is starting off with a positive reputation.
Afternoon gents (and ladies?)
i recently purchased my van after owning a express for many years, I liked the design of the ford much more so decided to go with it.
However this morning I was driving a long and suddenly overheated, I pulled over and the redo por was empty so I proceeded to fill it. I then noticed all the fluid dropping out from under the truck.
I got towed home and proceeded to pull apart the rear engine cover to look for a blown hose or the like.
I filled the tank again and noticed water pouring out of a little upspout connected to the Manifold cover.
I searched and searched and couldn’t find anything, is there meant to be a hose here or is this some kind of over flow.
Thanks in advance.
Old 11-09-2017, 08:45 PM
maples01's Avatar
maples01
maples01 is offline
maples01 has a good reputation on FTE.maples01 has a good reputation on FTE.maples01 has a good reputation on FTE.
Was there nothing on it, I looked at photos of mine, it's a 5.4 and it doesn't have that, it had an aluminum intake too, not plastic which I've heard can warp and leak when overheated. The images I get on the internet have that capped.
Intake Manifold Lobo F150 Pickup E150 E250 Van 2007 2008 New 7L3E9424
Old 11-09-2017, 08:48 PM
maples01's Avatar
maples01
maples01 is offline
Yes, everything I find has it capped off, guess thats why mine doesn't have it, they don't use it, but the 4.6 may have an application where it uses it so instead of making one special intake, all have it, they just put a plug on it.
Old 11-09-2017, 09:32 PM
Winstonx
Winstonx is offline
Hey bud thanks for the reply, i to am wondering if it was just perhaps capped. My boss has the 4.6 E150 and his is capped. I guess i'll try capping it and see what happens, there was no sign of a hose on it when i removed the interior engine door.
Finding a cap could be the issue so i may use a little bit of hose and a 3/4 copper Cap with a hose clamp and see if it works
Old 11-09-2017, 10:12 PM
maples01's Avatar
maples01
maples01 is offline
I looked and everything was capped, I would love to see what uses it, perhaps the police package.
Old 11-09-2017, 11:05 PM
Winstonx
Winstonx is offline
Who knows?!
A friend of mine said it could be something to do with the bigger trucks Triton and up apparently the manifold is the same but he's not a mechanic either so take it with a grain of salt.
Anyhow i appreciate your time, i'll throw a cap on it tomorrow AM and see what happens.
Old 11-10-2017, 11:24 AM
Mike1
Mike1 is offline
Mike1 is gaining momentum as a positive member of FTE.
I believe it's a coolant bypass port. If it's about 1" in Dia, this would be the Part # at Advance auto, not sure if that the parts store number or the Dorman number, Part #02250
Old 11-12-2017, 06:38 PM
Winstonx
Winstonx is offline
Yes, you are correct. I fabricated a home made cap and its back to running strong again.
Thanks for your help guys.
Kraut
Exhaust Systems
07-05-2007 03:04 PM
farmF-150
1997 - 2003 F150
15
02-08-2006 06:26 AM
Kraut
09-13-2005 09:29 PM
oubrad
2004 - 2008 F150
04-19-2005 01:26 AM
brobb
Engine Swaps
11-01-2004 02:38 AM
Quick Reply: 2008 Ford E250 4.6V8 Water leak PLEASE HELP
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
