K&N for a 4.9L?
Old 11-09-2017, 07:06 AM
Building_Fords's Avatar
Building_Fords
Building_Fords is offline
Building_Fords is gaining momentum as a positive member of FTE.
K&N for a 4.9L?
All, ok I am really pleased with the way the truck is running and am now just tinkering to work out gremlins... That said, the truck is pretty much stock, and I have thought about putting a K&N filter on it. I know bigger engines like to "Breathe" better, but am wondering if the 4.9L will benefit from the K&N.... Any Ideas?
Old 11-09-2017, 07:49 AM
Olds64's Avatar
Olds64
Olds64 is offline
Olds64 is starting off with a positive reputation.
You won't detect any difference with your "butt dyno" by installing a K&N filter. If you gat a K&N airbox kit you may be able to detect a little bit more engine noise. The HP boost is negligible. Get it as a fun project to do to your truck instead of planning to roast the tires with a HP adder. I have a K&N filter on my Oldsmobile and it runs fine. Just don't forget to service it regularly.
Old 11-09-2017, 07:54 AM
jas88's Avatar
jas88
jas88 is offline
jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.
Something you will be able to feel with your butt dyno, at least I did, is if you cut off the silencer part of the intake tube. So remove the air intake tube that goes from your grille to the air box. The part that protrudes into the air box, cut off the part where it skinnies down to a smaller opening. That is there to prevent you from hearing the air going into the box, but it also restricts flow. My 460 truck originally had the Six in it.
Old 11-09-2017, 08:01 AM
timbersteel's Avatar
timbersteel
timbersteel is offline
timbersteel has a good reputation on FTE.timbersteel has a good reputation on FTE.timbersteel has a good reputation on FTE.
The only feeling your gonna get from a K&N filter is a Lighter wallet. It's proven to allow more air in with more trash into the engine. It doesn't filter the air near as well as a paper filter. And the cost, well...add the initial amount for buying it, then the oil to "re-oil' it and that's a waste in my book.
A paper element is good for 12,000+ miles. Maybe more depending on your driving habits.
And the stock airbox on a 300 is a Cold air intake, nothing else is needed.
Old 11-09-2017, 08:03 AM
Olds64's Avatar
Olds64
Olds64 is offline
Here are various K&N style filters for a Ford 4.9L:
https://www.summitracing.com/search/...4%2B4294918852
Don't rule out the Summit brand just because it's "cheap." It's probably made in the same factory.
Old 11-09-2017, 11:53 AM
sandymane's Avatar
sandymane
sandymane is offline
sandymane is gaining momentum as a positive member of FTE.sandymane is gaining momentum as a positive member of FTE.
Just an FYI. The $128.00 Summit filter is for a MAS system as noted under details. Sandy
Old 11-09-2017, 12:48 PM
Olds64's Avatar
Olds64
Olds64 is offline
Right on battle, I didn't click on the filters to see what they were compatible with, I only searched for Ford 4.9L.
FWIW, I actually have a Fram AirHog filter on my Oldsmobile. It's the same thing as a K&N. Rechargeable; and as timbersteel said, it allows more grit and nastiness into the engine. It sure looks cool though!
Old 11-09-2017, 02:10 PM
jas88's Avatar
jas88
jas88 is offline
All I can say is I have run several engines over 200K using a K&N with no troubles so, if it does let in more dirt, it's not enough to hurt anything.
Old 11-09-2017, 04:52 PM
Mudsport96's Avatar
Mudsport96
Mudsport96 is offline
Mudsport96 is gaining momentum as a positive member of FTE.Mudsport96 is gaining momentum as a positive member of FTE.
From the factory the 200hp/270lbft tq 302 and the 245hp/400lbft tq 460 have the same air filter.
Not to be jerky, but I think the stock unit is probably fine on a 300.
And it saves $$
Old 11-09-2017, 05:34 PM
GoinBoarding
GoinBoarding is online now
GoinBoarding has a good reputation on FTE.GoinBoarding has a good reputation on FTE.
As stated, 300-6 and the bigger engines share the same filter size. I have a mildly built 351, so probably ~double the air flow capacity as a stock 300six, and have not noticed any difference in power between a paper filter & K&N. What I have noticed is a dirty MAF sensor with the K&N. I run synthetic Wix filters now.
Old 11-09-2017, 08:16 PM
TexasGuy001's Avatar
TexasGuy001
TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
I've had those filters on a few different vehicles in the past and never noticed anything positive about them, I can not endorse them at all. I especially hate cleaning and oiling them etc. Just stick with a nice Wix, Motorcraft, or Purolator.
F-1
Ford Truck Parts for Sale
09-05-2016 05:44 PM
mrcman58
12-31-2015 08:43 PM
IHateCommieCars
12-21-2014 03:47 AM
guitarnik
01-31-2009 09:11 PM
Quick Reply: K&N for a 4.9L?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
