Gtp38 with 1.0 exhaust housing vs gtp38r
Anyone go from a stock turbo that they swapped the .84 exhaust housing to a 1.0 and ran for some time then upgrade to a gtp38r? Most gtp38r reviews I have seen came from people that had the stock exhaust housing on the stock turbo before.
my understanding is that the gtp38r has a 1.0 exhaust housing. I am wondering if a gtp38r will be much better than what I currently am running. (Gtp38 with spturboost compressor wheel and banks 1.0 exhaust housing) I noticed a huge difference when I went to the 1.0 exhaust housing and am wondering if that is the big part of the magic with the gtp38r?
TLDR I'm thinking about buying a gtp38r for a good price and am not sure how much of an upgrade it would be
Is it possible to have my signature show when posting from my phone?
I haven't seen the signature be able to show when posting from a phone. I can't speak to the difference going from the stock housing equipped turbo then the 1.0, then 38R. I have gone from stock with WW gen 1 with S&B intake and 160/30's to the 38R. There is a LARGE difference between the 2. The intake on the 38R is a full inch bigger, more air in, more air out. It really REALLY woke the truck up.
The inducer diameter is all that matters. Actually, a small amount of gain one would get from the 66mm over 60mm inducer is lost with the "map enhancing" ported housing losses. The added diameter of the intake tube does NOT add anything to how much air the turbo takes in.
This is an HT60 from an N14 Cummins with a 5" inlet for a similar concept.
I have a stock Turbo with a Wicked Wheel and a 1.00 non wastegated housing I just ordered a kit to convert my Turbo basically into a 38r, kinda like the diy kit that riff-raff and KC turbo sells, but only paid $300 for everything. I will be getting the parts tomorrow and installing them after work I will post back to let you know the difference it makes
What you may have purchased is a kit to install a larger compressor wheel and housing. This was commonly referred to as a D66. It may be somewhat better then a stock turbo, under certain conditions, but it is not anything at all like a 38R or a KC38R. In fact, trying to drive the larger compressor wheel with the stock turbine may actually result in a loss of performance, as you may experience more lag. Even more so when combined with the 1.00 exhaust housing, and further so if one were to use this combo on a manual trans truck ( which already has a hard time keeping the turbo spooled between shifts.
It is somewhere between highly unlikely and impossible that you purchased a kit to "convert my Turbo basically into a 38r". One of the biggest benefits of the 38R ( as well as the KC38R) is that they are a ball bearing design, as opposed to the stock journal bearing. Any kit that "converts" a stock turbo to something like a 38R would require a replacement center housing and shaft/turbine, in order to make it a ball bearing design. As far as I know, no such conversion exists. If it did/does, I seriously doubt it would only cost $300.
All 5 of BridgeMonkey's posts have related to turbos, three of which posted a link to a ball bearing CHRA by Pulsar, one of several names in the aftermarket turbo replacement market (eg Sun Top High Tech Manufacturing, Industrial Turbo, Pulsar Turbo Systems) all headquartered in Jiangsu, China.
A number of US based vendors (some of whom are widely known) import turbos and turbo parts originating from Jiangsu, and resell them here, typically under their own brand names.
Chinese business culture has fostered a marketing concept best known by the acronyms "KOL" and "KOC." (Key Opinion Leaders, Key Opinion Consumers).
The principle behind KOC is that a consumer is provided with a product in exchange for agreeing to talk about that product, thus leading other consumer opinions about the product. If the company talked about the product, other consumers might dismiss that as advertising. But if a key opinion leading consumer talks about the product, the company hopes that might be perceived more favorably by other consumers.
And the company would be correct. I've witnessed this process of pre-meditated peer to pear influence employed quite effectively here on FTE.
The FTE Site Guidelines calls it "cheerleading," and forbids it.
Yet it is perhaps one of the least enforced guidelines, as every member is always afforded the benefit of the doubt, even in situations were it appears that the intent of every post is to promote the same product.
Yet, what if the intent was simply to share an overwhelming excitement about the product, or an unbelievably good deal in resolution of a well known common issue, etc. Our forum's last name is, after all, "Enthusiasts", so it is perfectly understandable for members to be enthusiastic. We want to encourage that enthusiasm to become contagious.
That enthusiasm is what led most of us to join FTE. That or frustration with Fords. Perhaps more the latter, now that I think of it.
It is equally understandable for members to be cynical, regarding certain posts with particular traits with some circumspection.
It all balances out in the end.
The following users liked this post:
I can 100% assure you I am not a cheerleader for a Chinese turbo manufacturer. And I take no offense.
I simply want to share information on a product I did not know existed and couldn't find any information about, prior to my purchase. I'm more than happy to build my truck on a budget, because I don't have money to blow. I build bridges for a living, hence my name, a dirt guy always called our division bridgemonkeys, so I endearingly embraced it. These trucks are over 20 years old and all the parts are still incredibly expensive from some manufacturers. If I can save someone else a dime, mission accomplished.
I do all my own work on my truck and take pride and joy in it. The frustrating times all become worth it when you hit the road. Yesterday I installed rear drop shackles, I knew going into it from research that the lower bolts would be a PITA. Plasma is my friend.
