7.3 runs cold...I think :/
Start with a new thermostat. They do go bad and fail open more often than not on these trucks. If you oil temp never goes above 140 or so, the truck is not reaching normal operation temp. Your fuel economy is greatly suffering as well.
Highly recommend either the IH or Dieselsite 203deg thermostat instead of the motorcraft 180deg one.
Its just 3 bolts to change it.
Did you gut your EBPV?
Stewart
Run it up into the 140s or whatever you are maxing out at and then grab the return hose to the radiator and see if you can tell if the tstat is popped open already. My 6.0 is running in the 160s-170s in 40-50F weather, so I checked and the tstat appears to be wide open, so new tstat going in next week.
90pioneer
05-07-2011 04:30 PM
boggerted
05-18-2007 09:09 PM
greg305
03-09-2006 04:10 PM
