Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Bill, 5 spd trans
Old 07-21-2017, 11:10 PM
C600's Avatar
C600
C600 is offline
Bill, 5 spd trans
Bill, I'm thinking of looking for a 5 spd, 5th over gear box for the 56 C 600 I'm building, it currently has the 4 spd in it, I have the extra parts from a direct 5 spd, hand brake parts, even the drive line but would like to put 5th over as long as its not that mrisable working short 5th, what would the number for that box be, this truck ow has a 312 in it.
Old 07-22-2017, 01:21 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
No 312's factory installed in trucks, cars only. Passenger Cars: 1956/57 Ford/Thunderbird & 1956/60 Mercury.
B6T-7001-B: Clark model 250-VO Medium Duty 5 speed Overdrive: 1956 F600 272 4V .. Case marked 5DB
Clark 5 speed overdrive available 1956/64. 1957/64's also available with a New Process 5 speed overdrive.
Old 07-22-2017, 10:30 PM
C600's Avatar
C600
C600 is offline
Thanks Bill, this truck was born with the 272, someone slipped in the 312 before this owner bought it, I had it torn down for an over haul, its a 57 312 with a 4 barrel, I haven't put it on the road yet, need to finish a couple other things,I hauled it to a show last week, now its back in my shop.
I'll look at the 5th direct box I've got for the number, I would like the same style box as it only in over, hoping that the shift lever is in the same place.
Thank you
Old 11-06-2017, 09:28 AM
C600's Avatar
C600
C600 is offline
Bill I finally looked at the direct 5th box I've got and the only number on it is C-80101 and all the is on the door plate for that truck is 5 Dir no other numbers, looking in the parts book I see the same number you gave me for the over trans. Is that 7001-B the same as the clark250-VO as far as same case and mountings for hand brake and PTO.
Thank you
Old 11-10-2017, 11:06 AM
NumberDummy
Thank you
B6T-7001-B =
Old 11-15-2017, 12:00 AM
C600's Avatar
C600
C600 is offline
What about changing the gearing in the direct box I've got to an over box, If I could find the gears, would some of the direct box gears be able to be used.
Old 11-15-2017, 01:47 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,579 Likes on 1,288 Posts
Pretty sure that's going to require the entire gear set. Better to seek out the entire transmission.
Old 11-15-2017, 08:47 PM
C600's Avatar
C600
C600 is offline
I did a quick look see in the parts book between the two, and it looks like some can be used and need to get a couple others, I'll need to take some time and work both boxes up and see what comes out.
1985tullyhowell
10-12-2014 12:21 PM
73FordF100
15
12-18-2011 03:44 PM
2speed
08-11-2010 03:15 PM
shawn_N
03-05-2009 06:17 AM
bluegrassfive
11-02-2008 06:44 PM
Quick Reply: Bill, 5 spd trans
