Complete locking mechanisms 51 F1 - Ford Truck Enthusiasts Forums
Old 11-07-2017, 11:16 AM
ric925az
ric925az is offline
ric925az is starting off with a positive reputation.
I need everything, mechanism, rod, latch, striker plate and post for both doors or a work around. Suggestions? Will hardware from a 53 work?
Old 11-07-2017, 12:21 PM
pweng1's Avatar
pweng1
pweng1 is offline
pweng1 has a good reputation on FTE.pweng1 has a good reputation on FTE.pweng1 has a good reputation on FTE.
If you need it all just do a after market pop lock system. It gives you push button control on both doors. Buying all the internals may be pricey.
Old 11-07-2017, 12:29 PM
ric925az
ric925az is offline
Thanks, looking at that also as a solution. Any suggestions?
Old 10-11-2018, 04:44 PM
ric925az
ric925az is offline
Still looking for locking door latches< RH and LH. Any suggestions would be helpful. Have the old ones but they are well used.
Old 10-11-2018, 08:17 PM
pineconeford's Avatar
pineconeford
pineconeford is offline
pineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant future
Hi ric,
Since you live in Arizona your best bet may be to buy a set of complete doors from a larger truck (F4 to F8) at a junk yard and plunder everything you need. It has been my experience that buying all the used parts piecemeal will cost quite a bit when you include shipping. Doors from a larger truck like a firetruck won't get much use and would have been further away from the ground so they would have stayed cleaner and drier over time. Some folks sell a pair of doors for $150 if you pick them up. Then maybe you can sell the door shells and get some money back.
You can also get most of the parts new from Dennis Carpenter or LMC or Mid-Fifty - but it will cost a lot - not sure if you are prepared to do that. It is the fastest way to have everything you need and at the same time you can get the new weatherstripping and rubber seals.
Hope this helps,
Tom
Old 10-11-2018, 11:41 PM
FortyNiner's Avatar
FortyNiner
FortyNiner is offline
FortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud ofFortyNiner has much to be proud of
There is an eBay seller offering new RH & LH door latches. Can't speak to the fit or quality but will give them a go myself soon. Search using ​​​​'ford truck door latch'.
Old 10-12-2018, 11:33 AM
ric925az
ric925az is offline
Originally Posted by pineconeford View Post
Hi ric,
Hope this helps,
Tom
Thanks, looking into finding some. That is where we got these.
ITDave
2004 - 2008 F150
07-11-2012 02:10 AM
doubledoyle
04-23-2008 08:10 AM
HateTank
07-09-2007 11:42 AM
bbearls
05-17-2007 07:47 AM
bcguys
09-04-2002 07:41 PM
Quick Reply: Complete locking mechanisms 51 F1
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
