High boost - no pull - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 11-07-2017, 10:54 AM
Picton's Avatar
Picton
Picton is offline
Picton is starting off with a positive reputation.
What could be causing this?
The turbo seems to work more than it should...and the truck doesn't seem to pull like it should. I experience the issue regardless of the tune I'm running. Just recently went back to the "DPF Off" stock HP tune. Same issue. Entering the freeway with an entrance ramp going up hill is where the issue really shines. You'll hit over 20psi, 2k rpm and feel like your not going anywhere. Could this be an exhaust back pressure sensor issue? I don't know what else could be causing this. My truck isn't throwing any codes and never has since I first started noticing this.
Thoughts?
Old 11-07-2017, 01:06 PM
Firefighter 1406's Avatar
Firefighter 1406
Firefighter 1406 is online now
Firefighter 1406 has a great reputation on FTE.Firefighter 1406 has a great reputation on FTE.Firefighter 1406 has a great reputation on FTE.Firefighter 1406 has a great reputation on FTE.
Any black soot under hood?
Old 11-07-2017, 01:33 PM
Picton's Avatar
Picton
Picton is offline
None at all. Also...I don't recall having this issue until I removed the DOC. Which was done thousands of miles apart from the DPF.
Old 11-07-2017, 06:42 PM
slowmans's Avatar
slowmans
slowmans is offline
slowmans has a good reputation on FTE.slowmans has a good reputation on FTE.
Old 11-08-2017, 04:28 PM
Picton's Avatar
Picton
Picton is offline
Originally Posted by slowmans View Post
Yeah I've seen that video before. Sure sounds like it. Though I don't have smoke coming out of the tailpipe. I'll give it a good cleaning anyway. If that doesn't fix it, I'll replace the sensor. So like he says in the video, I guess the best angle of attack would be from the driver side fender well. I assume he took the wheel/tire off?
Old 11-08-2017, 07:59 PM
Picton's Avatar
Picton
Picton is offline
I had another thought. Since this started happening around the time I finally deleted the DOC, I have it in my head that the delete is possibly the issue. Does the engine have enough back pressure once you've deleted the DOC/DPF? Surely that can't be the issue as I've not heard of anyone complaining about loss of power and high boost due to deleting the emissions equipment.
Sorry fellas...I may have just had a complete conversation with myself on my own thread.
Probably the EBP sensor...or the tube it sits in getting clogged up with soot. Which would be especially possible with my driving conditions...short trips...often not allowed to really warm up (though we're talking Houston, TX...They don't even recommend plugging the truck in until you've reached -20*...or was it 20*...either way in Houston we're not hitting those marks) so it could coke up a bit. Hopefully that is all it is.
Old 11-08-2017, 08:27 PM
DieselDenny
DieselDenny is online now
DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.
Kinda thinkin that your steering a good course Pic.
Let us know.
How about pulling cables overnight. Clearing codes first and then take the girl to prom so you have a fresh insight.
Denny
Old 11-08-2017, 09:52 PM
Picton's Avatar
Picton
Picton is offline
slowmans...Apologies. I just realized I didn't thank you for the tip and the video link. You're the man for that one!
Denny - Thanks for the positive reinforcement...once again...I find myself not 100% certain as to your meaning...lol.
I don't have any codes being thrown...unless by putting on a new EBP sensor will throw a code that needs to be cleared? All I know is...prom night...**** is going down.
Old 11-09-2017, 07:26 PM
slowmans's Avatar
slowmans
slowmans is offline
No Problem, i think that is going to be your issue!
Old 11-09-2017, 07:31 PM
Picton's Avatar
Picton
Picton is offline
Let's hope so!
Old 11-10-2017, 12:58 PM
Firefighter 1406
Interested to see what you find out.
Old 11-12-2017, 05:20 PM
DieselDenny
Any findings?
Old 11-12-2017, 05:38 PM
Picton's Avatar
Picton
Picton is offline
Originally Posted by DieselDenny View Post
Any findings?
Not yet Denny. Didn't get a chance to really look at the sensor until this afternoon. If I were to try to clean...the sensor sits right on top and the port where Bill Hewitt cleaned was at the bottom at the exhaust manifold. Correct? Of course the placement doesn't easily allow for a tool on either end. And the mounting bracket the tube is held in place by doesn't look nearly beefy enough to handle the torque that may be required to remove the EBP sensor a the top. The sensor lug is thick. Anyone know the tool? At either end?
Do I remove the fender well shielding? Does it go back together well? That can be a potential royal pain to bolt back in.
Thoughts?
Old 11-12-2017, 07:14 PM
DieselDenny
Pic, might be chasing a rainbow on this problem, but maint is maint. In my footsteps, it's never been the device, it's always the delivery man. I would pull the tube and send a team of oscillating fibromastic crap down it and then do a recheck. Then replace the sensor.
I'm still pondering the WHOLE issue.
Denny
Old 11-12-2017, 07:39 PM
Picton's Avatar
Picton
Picton is offline
Denny
Don't know about a rainbow...there is some information on the issue I'm having possibly related to the EBP sensor. Worth investigating. I'll let you know.
Quick Reply: High boost - no pull
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
