1986 F150 wire harness - Page 4 - Ford Truck Enthusiasts Forums
  #46
Old 11-15-2017, 06:03 PM
FuzzFace2's Avatar
FuzzFace2 FuzzFace2 is online now
FuzzFace2 has a very good reputation on FTE.FuzzFace2 has a very good reputation on FTE.FuzzFace2 has a very good reputation on FTE.FuzzFace2 has a very good reputation on FTE.
Quote:
Originally Posted by Longstroke View Post
They were NOT plugged together. I can't remember off the top of my head where they plugged in to. I will look everything over this weekend so I can let you know.
Do you need any plugs?
If they were not plugged together then they were plugged into the AC harness, brown/orange and brown/white.
Now I got some good news bad news on my wires.
I think I found where them cut wires go after looking at this link again for the 100th time. A/C & Heater - ???Gary's Garagemahal
Down on page 145 and the light bulb went off! I had to go to my garage and dig in 1 of my parts bins to find the HVAC control panels I have and there it was!
Both are for factory AC. 1 on the right is also for duel tanks (switch is on the left on the control when looking at it.
and the money shot!
I looked them over before and was looking for a large plug/socket like the switches.
Then looking over the link I saw it said HVAC control and a little lower picture it showed the wires going in on the end. Sure enough there they are.
Bad new I don't have that plug but I think I can use spade connectors and make it work. I just need the pin out as the one I saw was a square not in a line like I have.
If you look on the rear of your control panel the AC harness should plug into it. Could you list the color of the wires top to bottom that would help.
You will need this (AC) harness and plugs to repair if you cannot find one in a junk yard. IIRC there are only 2 wires (green/purple & black/yellow) that go into the engine bay (they go thru firewall under the HVAC box) from this harness.
Now if you find a complete harness with AC and not going to use that AC harness I would take it for that control panel plug and I could then splice it onto mine.
Thank you for your help looking over your harness to check things out.
Dave ----
  #47
Old 11-15-2017, 08:30 PM
Longstroke Longstroke is offline
Longstroke is starting off with a positive reputation.
If I don't end up needing mine, you are most certainly welcome to it. You still need the order that the wires go in. Right?
  #48
Old 11-16-2017, 10:13 AM
FuzzFace2's Avatar
Yes on the order the wires go in when you can no rush.
I still need to do a little more wiring & gauge cluster before I can put power to the truck and see if it will run.
I also don't have the brackets for the AC compressor or hoses.
thanks
Dave - - - -
  #49
Old 11-16-2017, 12:43 PM
Right side top to bottom closest to the 45s:
orange with a red stripe and blue with an orange stripe.
on the left side from top top bottom:
black and orange with a brown stripe.
  #50
Old 11-17-2017, 08:30 AM
FuzzFace2's Avatar
Is that the fan switch wire color pin out?
I needed the wire pin out for the wires going into the back of the HVAC control panel.
They would be the 2 brown/white wires, green/purple and black/yellow wires.
I say "needed" as I did find the pin out for them.
I also found out the early control had a square plug and later years a in line plug like I have now.
When I get on my computer I will start a post on where to get the plug with part numbers as I couldn't find details on them.
Dave - - - -
  #51
Old 11-18-2017, 12:52 AM
That is the pin out for the gray plug that plugs in to the back of the HVAC panel on the left side. It's for the blower switch. Most things concerning wiring are a complete mystery to me. I'm not intentionally being a bone head. I'm sorry if I'm not being much help.
  #52
Old 11-18-2017, 07:00 AM
FuzzFace2's Avatar
Not a bone head at all and I am happy you are helping me on this issue. Besides I am sure it will help you when you start the re-wiring project on your truck.
The pin out I needed (I did find it with help on the other Ford truck site I am on) but will help you.
Not the sockets on either side but in the very end/center, the black/white socket that has the white vacuum nipples (on the left side of socket) on it has 4 pins in a line.
I found on early trucks this was a square socket and later trucks went in line like the 2 controls I have. I don't know what you may have but thinking in line as you have a really later truck being an 86. So when JY hunting just keep an eye on the AC plug harness that will work with your control or get the control from the JY truck the harness comes from.
The lever that controls the vent doors with AC has this switch built into it that turns on the compressor.
I am now seeing if I can buy a new plug to splice onto the cut wires other wise I will add to the cut wires and ends to fit the socket pins.
Clear as mudd right
Again thinks for your help
Dave ----
  #53
Old 11-18-2017, 09:00 AM
FuzzFace2's Avatar
Looking over the picture you first posted the heat looks to be at the batt/ALT area.
Bill/aka ND said in his post of gauge harness then ALT harness the cause of fires.
I have seen a lot of post of the ALT the cause of fires and I am thinking that is what your cause was.
I would think if it was from the carb you would have more heat damage on the left side of the engine bay.
That is 1 of the big reasons for the 3G ALT swap so no fire.
Dave ----
  #54
Old 11-18-2017, 01:28 PM
Yes sir. I think you are correct plus I've been reading Bill's answers to things for years on here and I think he is a genius.
  #55
Old 11-19-2017, 10:42 PM
Hey Dave, SCORE!!! I bought an 82 model parts truck today that's complete us the motor and transmision. The wiring harness is all there and not butchered..Plus all the other stuff I need like the windshield wiper motor.
  #56
Old 11-20-2017, 06:13 AM
FuzzFace2's Avatar
Good to hear you found parts.
I would also look into the 3G ALT swap as I think that is where the fire started with your 2G ALT.
The 82 may have a 1G ALT but I am not sure on that but would be ok yo use as it does not start fires like the 2G as I seen posted about.
Dave - - - -
  #57
Old 11-21-2017, 01:05 AM
I took your advice on a parts truck and I'm thinking it's going to save me hours of frustration and parts chasing.
I'm one step ahead of you. Im already searching the 3G swap. I did use one of the Generals one wire alternator on a 73 F100 with a 460, so I might go that way. I'm not sure yet. I do like the idea of my Ford being all ford, but that GM alternator was stupid easy to put on that 460.
  #58
Old 11-21-2017, 10:48 AM
FuzzFace2's Avatar
On another forum I am on guys have issues of 1 wire ALT'S not keeping the battery charged.
The sensing wire inside the alt gives a false reading of the batt and not charge it.
I will never run a 1 wire alt but that's me.
Dave - - - -
  #59
Old 11-22-2017, 12:52 AM
The one wire alternator never once gave me a problem.
I am very interested in the 3G swap. I just wish there was a way to make the factory gauge work.
I'm kicking around the idea of hooking it up to an after market light of some kind to serve as an idiot light.
my 5 glassmanbruce 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 11-01-2017 10:07 PM
1952 ford f1 parts new and used) 52 Ford F1 Ford Truck Parts for Sale 0 10-30-2017 09:15 PM
Fabricated engine parts 79f1501ton Performance & General Engine Building 1 05-28-2017 12:00 AM
1987+ Ford F150 Ignition Switch Basics one_bolt_short 1987 - 1996 F150 & Larger F-Series Trucks 1 05-25-2017 09:15 AM
Restoring 1972 f100 67336f100 1967 - 1972 F-100 & Larger F-Series Trucks 20 04-19-2017 08:35 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
