1986 F150 wire harness - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 11-13-2017, 07:17 AM
FuzzFace2's Avatar
FuzzFace2 FuzzFace2 is offline
FuzzFace2 has a very good reputation on FTE.FuzzFace2 has a very good reputation on FTE.FuzzFace2 has a very good reputation on FTE.FuzzFace2 has a very good reputation on FTE.
Just got thinking of something.
I don't know as I did not look into this, both on my truck used gauges.
I wonder if the plug for the gauge cluster is different between gauges or lights?
It maybe the same type of plug but some of the wire pin outs on the plug may be different?
Something to keep in mind when looking.
Dave ----
  #32
Old 11-13-2017, 09:41 AM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
The plug for the idiot-light cluster is the same physical style but has fewer wires/connections (and is oriented vertically IIRC as opposed to the horizontal mounting of the gauges cluster).
This is as I remember it, this used to be a well-documented topic but many pictures have gone away at this point.
  #33
Old 11-13-2017, 10:49 AM
FuzzFace2's Avatar
So with fewer wires that could be an issue with the harness then.
Dave ----
  #34
Old 11-13-2017, 12:43 PM
Longstroke Longstroke is offline
Longstroke is starting off with a positive reputation.
My plan is to get the earlier harness along with a gauge panel, starter solenoid, A/C box (under the hood), A/C controls, fuse boc, etc all out of one truck. I've run in to plugs being different on stuff before so I'm going to be extra care full on parts selection.
Dave, what color are the wires that are cut? I have wiring diagrams. Maybe I can help you.
  #35
Old 11-13-2017, 05:35 PM
FuzzFace2's Avatar
I can do a link to a post trying to find what the wires go to. It is the group of cut brown/white wires the rest in the post I figured out.
https://www.ford-trucks.com/forums/1...cut-wires.html
Now I could be wrong on what the post said the brown wires go to as no one could find them and I have not dug deeper into it just yet.
I thank you for looking into it.
Dave ----
  #36
Old 11-13-2017, 08:01 PM
Brown wires with a white stripe?
  #37
Old 11-14-2017, 08:01 AM
FuzzFace2's Avatar
Think that's what I have in the post.
there could be an browbeat with orange but don't remember now as I have not worked on that part in a few weeks.
just thinking here your truck has AC what color are the wires going to the fan switch?
Dave - - - -
  #38
Old 11-14-2017, 12:30 PM
Are these the ones you're asking about?
  #39
Old 11-14-2017, 05:33 PM
FuzzFace2's Avatar
Kind of sort of,
Do they have male/female plugs and plug together like in this picture?
If so that is how a Non-AC harness it wired. Picture is of my Non-AC harness.
Now when the factory installed AC they would un-plug the 2 wires and plug in the AC wiring harness into them.
This picture shows the AC harness plugged into the 2 wires.
Now what I don't know and cant make out from this link, page 100 (my color of cut wires) page 101 (not my colors on the blower switch)
Component Testing - ???Gary's Garagemahal
Did the AC harness have it's own blower switch plug and the factory Non-AC fan switch plug was left unplugged?
If so then why in the link do the 2 plugs have different shapes?
So if you have AC what was plugged into the 2 plugs in your hand and what color are the wires & shape of the blower switch plug?
Dave ----
  #40
Old 11-14-2017, 07:58 PM
Dave, the blower switch plug is a black "L" shaped plug that has either 3 or 4 wires going to it. I can't remember what color the wires are, but I can post a picture of that plug nd the wires tomorrow. I did not see that particular plug any where in any of your pictures. Do you need one?
  #41
Old 11-14-2017, 08:46 PM
FuzzFace2's Avatar
If you can check on the shape & color and numbers of the wires in it.
I ask because mine is not "L". More like a square with the top corners trimmed at about a 45*
In the picture below the gray plug at the front is what it would look like but that one is for the duel tanks. The gray one behind the brown plug is for the blower and has the right color wires based on the link on Garys site page 101.
That site shows my brown wires on page 100 in a square plug but I don't know where it plugs into?
Dave ----
  #42
Old 11-15-2017, 12:26 PM
And here are the wire colors.
  #43
Old 11-15-2017, 12:55 PM
This is my blower switch plug. My truck has factory A/C.
  #44
Old 11-15-2017, 12:58 PM
FuzzFace2's Avatar
Ok so that is the plug/wires to the blower switch as the colors look to match mine behind that brown plug and to Gary's link.
You didn't see another plug in that area with the brown/white wires did you?
From the link page 100 there is a plug with the color wires and looks to be for the AC but I don't know where it plugs into?
Right now I could beat the guy for cutting the wires because of this.
Thanks
Dave - - - -
ps did you have anything plugged into them brown/orange wires that were in your hand not plugged together?
  #45
Old 11-15-2017, 03:17 PM
They were NOT plugged together. I can't remember off the top of my head where they plugged in to. I will look everything over this weekend so I can let you know.
Do you need any plugs?
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
