EGR Cooler & DEF tank heater replacement and warranty ? - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.7L Power Stroke Diesel
Reload this Page >
Old 11-02-2017, 09:29 AM
longrange1971
longrange1971 is offline
longrange1971 is starting off with a positive reputation.
Hello all,
Truck threw some codes the other day. Took it to Ford to find out it needs a EGR cooler and reductant tank heater. EGR cooler already replaced once under warranty, now they are saying the truck is out of warranty by 1 month and 16 days and they are not covering it. Very frustrating. I was wondering if there are any Ford warranty reps on the site? Thanks for your help. Oh yeah, the truck has 87,500 ish miles on it and it is a 2012. Makes me want to consider deleting everything!!!
can you successfully do a delete without replacing these parts and is it safe to drive for a period of time until i can figure this out
thanks again
Old 11-02-2017, 12:47 PM
Painted Horse's Avatar
Painted Horse
Painted Horse is offline
Painted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant futurePainted Horse has a brilliant future
What's the Warranty on the Replacement? Didn't the repair work have a separate warranty period from the trucks base warranty?
Old 11-02-2017, 01:22 PM
longrange1971
The replacement EGR Cooler had a 2 year warranty so it is out of warranty as well. it was replaced back in 2014 after 35,000 miles.
Old 11-02-2017, 03:08 PM
Jeffh40
Jeffh40 is offline
Jeffh40 is starting off with a positive reputation.
DOn't know about the EGR but the DEF heater is fine to run without until it gets to 12 degrees outside. That is when DEF starts to crystallize. Once it gets too cold outside, you'll get a "DEF failure - vehicle speed limited to 50 mph" warning.
My heater failed in Jan last year. Still haven't replaced it since I keep the truck in the garage. I don't drive it on those colder days though until I get it fixed or deleted.
Old 11-04-2017, 07:46 AM
longrange1971
Well to update things, on Wednesday my dealer was supposed to request warranty extension from ford then call me when they found out what ford said. Still have not heard back from them. IDK!!
Old 12-16-2017, 09:22 AM
longrange1971
So after the 3rd attempt with Ford, I was finally told there would be no financial assistance for work on a truck out of warranty by 1 month and 16 days. So I deleted it!!Mini max tunerSinister EGR delete kit 4” cat back pipe. Using same mufflerI could not be happier. Did it myself. Whole job took me about 8 hours just taking my time. Getting 21+ MPG on average. Drives like a different truck. Lovin’ It !!!!
Old 12-17-2017, 04:37 AM
falconetti
falconetti is offline
falconetti is starting off with a positive reputation.
awesome! probably cheaper that way too.
Old 01-12-2018, 01:30 PM
Slowlearner's Avatar
Slowlearner
Slowlearner is offline
Slowlearner is gaining momentum as a positive member of FTE.
My 2012 F-350 6.7 has also recently presented me with the P20BA code associated with the failed DEF tank heater. After clearing the code several times (as the service procedure directs), it has repeatedly and immediately returned, indicating a confident failure of the reductant tank heater.
While going through the troubleshooting process and chatting about it with some fellow 6.7 owners I learned that several of them have had the exact same issue occur in the 60k-100k mile range. Further internet /forum searching has made it seem that this is becoming a very common failure. In my case (and each of my friend's cases) the issue occurs just outside of warranty coverage, requiring a ~ $1,200 out of pocket repair expense.
I have reached out the Ford Customer service requesting that this issue be looked into. It seems that this issue is far too commonly occurring, and (almost conveniently) occurring just out of warranty coverage. It seems unacceptable that this component is regularly failing at ~60-100k miles, and at the owner's expense. Further, given that it is a emissions control component, it's a little off-putting that it is not covered under an 80k or 100k mile emission's warranty.
Fingers crossed that we will get some sort of extended support, or warranty extension similar to the program deployed to address plagued EGT sensors (which also failed on my truck).
Old 01-12-2018, 02:27 PM
2012F250SUPERDUTY4X4's Avatar
2012F250SUPERDUTY4X4 is offline
2012F250SUPERDUTY4X4 is gaining momentum as a positive member of FTE.2012F250SUPERDUTY4X4 is gaining momentum as a positive member of FTE.
My DEF tank heater went sour at 73K miles, I purchased a extended warranty for 75K miles so glad it went bad before. I still had a $100 deductible.
Old 01-12-2018, 06:50 PM
whitlock's Avatar
whitlock
whitlock is offline
whitlock is starting off with a positive reputation.
Mine went out on my 2011 at 94K...but I have ESP so $100 my cost.
Old 07-19-2018, 09:47 AM
porthole's Avatar
porthole
porthole is offline
porthole has a great reputation on FTE.porthole has a great reputation on FTE.porthole has a great reputation on FTE.porthole has a great reputation on FTE.porthole has a great reputation on FTE.
2011 - 103,000 miles - DEH heater fail
7.5 years old
Old 07-19-2018, 10:13 AM
Slowlearner
7.5 years old
Was your truck covered?
Customer Satisfaction Program
This program extends the warranty coverage of the reductant heater and sender assembly to 11 years of service or 120,000 miles from the warranty start date of the vehicle, whichever occurs first. If a vehicle has already exceeded either the time or mileage limits, this extended warranty coverage will last through December 31, 2018. Coverage is automatically transferred to subsequent owners.
VEHICLES COVERED BY THIS PROGRAM
F250 - F550 2011-2012 Built Aug 24, 2009 - Oct 23, 2012
F450 - F550 2013-2015 Built Apr 16, 2012 - Dec 9, 2014
Ford Motor Company is offering a refund for owner-paid repairs covered by this program if the repair was performed before the date of the Owner Notification Letter. This refund offer expires December 31, 2018.
Dealers are also pre-approved to refund owner-paid emergency repairs that were performed away from an authorized servicing dealer after the date of the Owner Notification Letter. There is no expiration date for emergency repair refunds. Non-covered repairs, or those judged by Ford to be excessive, will not be reimbursed.
Refunds will only be provided for the cost associated with replacing the reductant heater and sender assembly.
Old 07-19-2018, 01:05 PM
Jeffh40
Jeffh40 is offline
Just a quick update, I finally had mine repaired this spring. About $800.00. I can't remember exact mileage that it failed but somewhere around 130,000.
Old 07-19-2018, 01:11 PM
porthole's Avatar
porthole
porthole is offline
If your truck meets the guidelines - you may be eligible for a refund, all or part.
Old 07-19-2018, 01:36 PM
Jeffh40
Jeffh40 is offline
Certainly worth checking into. Anyone have the link to the actual TSB from Ford on this?
Quick Reply: EGR Cooler & DEF tank heater replacement and warranty ?
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
