Still won't start reliably
At about wits end with this dang truck. New batterys and glow plugs, gp relay has a good ground and works. Wait to start light comes on for a normal amount of time. Still does not start reliably. Gets fuel fine, I've already tried cracking the lines and cranking it. White smoke out the tailpipe. HELP!
on
If you're getting white fuel haze out of the pipe, fuel is fine.
How fast is the starter spinning?
What brand of GPs? Have you OHMed them with a meter to see if all are still good?
My controller cycles fine, but I bypassed it and went with a push button setup. Hold for 10 seconds first thing in the morning. It fires every time, and doesn't cycle every time I start when running around town.
on
Okay so you need to check your signal out of the module to the relay than you may have a module failure and its not powering it up. But sounds like a module or relay failure.
I started on the manual glow plug setup. I didn't do anything with the blue wire because I didn't get where it was supposed to go. I could still here the relay click so I figured it was heating the glow plugs. I don't think so. Wouldn't start. It only starts if I directly jump the big posts on the glow plug relay
Get a replacement relay and try that. My guess is that the relay's contacts are shot, but it still is "functional".
Be aware that there are two similar-shape relays - one for the glow plug controller, and one for the starter.
They are(or can be) the same size, same number of terminals...
On the glow plug relay, the coil or "control" terminals(what turns it on) are the two small posts.
On the starter relay, the coil terminals are one of the small posts(labeled "s" usually) and the steel base plate of the relay.
Be sure not to confuse the two, or it won't work right.
Once you have a new relay, test it by putting ground to one of the small posts, and power to the other. It should click(note: just test it in free space; it does NOT need to have anything else connected for this test.
Received 3,090 Likes
on
on
And *enough* power. I had a "working" relay, but it was losing about 2V(or around 20%) of the power through it, so all the glow plugs wouldn't heat up nearly as well.
