Fuel Pump Issue
Old Nov 1, 2017 | 10:54 PM
sandymane's Avatar
sandymane
Thanks for the reply. I did pressure check about 1500K ago. I have replaced the front pump this summer. I'll keep an eye and an ear on the rear one. Sandy
Old Nov 1, 2017 | 11:58 PM
NotEnoughTrucks2014's Avatar
NotEnoughTrucks2014
I think what is happening here is that the rear pump has become noisy. Possibly a sign of imminent failure?
Pumps are supposed to run continuously with the engine running. They share the same ECM, fuel pump relay, inertia switch, etc. So any difference noted between tanks is also isolated to that tank.
Old Nov 2, 2017 | 01:07 PM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
This is what I was thinking.
Fuel pumps have been known to act strange for years and still perform reliably.
Sandy, any chance you could post the link to the PIP stuff you read?
Old Nov 2, 2017 | 01:36 PM
sandymane's Avatar
sandymane
My history was cleared but I think this is what I read. In my post I was referring to the relay continually running but I was calling it the pump. Even I know the pump has to run to supply fuel.
I'm not sure about an '88, but on the later models ('94-'96) the "thing" that tells the ECC to continue running the fuel pump are the PIP pulses coming from the distributor, indicating that the engine is running.
The way it works: Turn the ignition to "on" and not to "start", and the ECC will run the pump(s) for about 1 second. Then the ECC waits to see the PIP pulses indicating that the engine is turning over. Keep getting PIPs and the fuel pump keeps running (the ECC tells the fuel pump relay to stay picked).
Old Nov 2, 2017 | 01:42 PM
HardScrabble
Thanks. That's the engine quits, pump quits thing. Don't need 45psi gasoline under the hood if you're upside-down in a ditch.
Old Nov 2, 2017 | 02:44 PM
sandymane's Avatar
sandymane
Listening to both tanks with a screwdriver, when selected, the front does not make the buzzing sound like the rear tank. You don't need a screwdriver to hear the rear buzzing. I made a recording of the sound but I have not been able to load it here. I would imagine all is well but I don't remember hearing the buzzing before. As I said, until yesterday, I haven't used the rear tank in a couple of months. Sandy
Old Nov 3, 2017 | 05:48 AM
HardScrabble
Eventually I will replace pumps and sending units in both tanks on both vehicles. Maybe high volume to support some power increases. Both of my old Fords have faltered on switching tanks in the past, years ago. One ran bad on one tank for a whole trip cross country, years ago. The original pumps must be tough. They healed themselves over the long haul.
I have a feeling that a lot of these old trucks are getting so bad that pump noise is way beyond what the users call a problem. Feel lucky that your hearing is good enough to hear it and your truck is quiet enough so you can hear it.
Johnks4x4
Feb 8, 2025 05:53 PM
foolgator1
Jun 14, 2012 12:38 PM
entity
May 11, 2007 06:14 PM
MIBPreacher
Jul 27, 2004 07:33 PM
dwpenney
Jan 8, 2001 10:24 PM
