Project 1990 F350 7.3IDI Flatbed
My latest budget build project is a 1990 F350 flatbed.
Truck was advertised on Craigslist for about $1600. Ad claimed it needed a new fuel pump. They took my offer of $1300 and I loaded it up.
Truck has a 7.3 IDI which I’m pretty sure has a T-19 in it now. It originally had an automatic trans.
I actually bought this truck about a year ago, I did a little work to it, got sidetracked with other problems, projects, side work, etc, worked on it again, let it sit, fixed a few more things, etc. I’m attempting to put it on the “front burner” now and finish it up. I’ll summarize what I’ve done already and post a couple of the pics I do have.
As advertised in the ad:
After some cleanup:
After some cleanup:
Long story short:
Installed a new lift pump, bled filter and lines and it finally started up. I noticed the fuel return lines leaking, so next it was replacing all the oil rings at the injectors. Fuel filter housing o-rings also replace. I took it for a spin down the road and started to realize this was the most poorly maintained truck I’ve bought in a long time. Everytime I took it for a test drive, a hose would start leaking, next a belt broke. I replaced hoses and belts and alternator.
I drove it around a few times and realized I was leaking coolant somewhere. I ended up pressurizing system to find leak, pulled the glow plugs and had water coming out. It was then I realized I had a bad head. (pressurizing the system with piston at TDC eliminated to me the possibility of the cylinder wall leaking) I pulled the head and found a crack:
Lesson learned (even though I already knew this, I did it anyways): best to buy a running vehicle unless it’s very cheap. Ha.
Found a head at local junkyard already pulled for $175. Installed the head and truck is on the road again.
I took about a 100 round trip with the truck, on the way back the stupid fuel filter starts leaking again. I made it home with diesel leaking all over the place with it smoking off the exhaust manifolds. I’m surprised the damm thing didn’t catch on fire. I replaced the POS two piece filter with the updated one piece filter and I’m back on the road. Now it’s on to bodywork and painting…
To catch up with the current progress: Unknown type of primer from pre owner was sanded off to bare metal and truck was sprayed with Nason epoxy primer. I’m currently working any dings and dents. BTW, if your doing bodywork, save yourself some work and skip the Bondo. I'm using Evercoat Rage and it is awesome and of course there are other good fillers on the market. They are easy sand and doesn't gum your sandpaper like Bondo does when you first start sanding. The bodywork areas, I usually clean up and shoot with epoxy primer. I’m getting close to shooting some primer surfacer.
Received 3,099 Likes
on
on
on
on
