Window sticks going up\down after replacing lock actuator
Old 10-31-2017, 07:56 PM
Crosma's Avatar
Crosma
Crosma is offline
4wd Low
After replacing the lock actuator in the drivers door the window jams up about 6" down. It worked just fine before. It's something to do with the vertical piece of window track that I unbolted to get at the lock assembly but as far as I can see and feel, everything is back in place and the track feels like it is straight. (It's clearly not.) The top of the track sits in a stamped sheet metal bracket and it seems like the rubber seal is supposed to lap over that piece of metal. But maybe its supposed to be fully inside the metal? I tried to do that but I got to a point where it didn't want to go in at the top and didn't want to damage it without finding more info.
Does anyone have any photos or a diagram of how its supposed to go back together? Tips? I'm failing to find relevant photos on Google.
Old 11-01-2017, 12:54 PM
Chad T. Keogh's Avatar
Chad T. Keogh
Chad T. Keogh is offline
Maybe open your passenger door up and use as a guide for how it should be? Just a thought.
Old 11-01-2017, 05:52 PM
Chad T. Keogh
Found this video. Might help. Not sure.
Old 11-04-2017, 04:50 PM
Crosma's Avatar
Crosma
Crosma is offline
4wd Low
I should have mentioned that I did the passenger side a month ago and while the window still goes up and down, it starts to stick at the same place the drivers door stops, so it's probably not a good comparison. Going to see if my friend will let me open up his door though.
I came across that video but it's not much help.
Old 11-07-2017, 12:28 PM
Lime1GT's Avatar
Lime1GT
Lime1GT is offline
The lower track you removed has a guide tab that needs to be slid into the upper track for proper alighnment. Make sure it's fastened properly.
Old 11-08-2017, 08:51 PM
Crosma's Avatar
Crosma
Crosma is offline
4wd Low
Lime1GT, thanks. My dad had a go at it and apparently he figured that one out. Was a pain, but it was the problem.
Crunk
11-03-2013 05:36 PM
bearhugger
22
04-03-2012 07:11 PM
JMM-MD
11-22-2011 08:33 AM
justintino233
12-01-2007 10:29 AM
muchomota43
1997 - 2003 F150
01-27-2004 11:01 AM
Quick Reply: Window sticks going up\down after replacing lock actuator
