C6 Linkage to Shift Rod Connection
1972 Camper Special
Hi, I recently ran into the same problem I can not get the bushing on. Is there a trick? Tried using huge Chanel locks won't grab on far enough to put even pressure on the bushing. Then vice grips but, can't get an even grip on those either. Any help would be great!
QUOTE=culpthm1;17558645]Hello all - looking for the correct grommet or bushing to connect the shift rod coming down from the steering column to the linkage on my C6 transmission. You can see the 1/2" hole in the shift linkage it needs to connect into. I tried purchasing a grommet that looks exactly like the one that broke from Advanced Auto Parts but it is made of hard plastic and there is no way to press the rod in. The inner lip that is to fit in the groove in the rod has a smaller diameter than the rod (3/8"). Thanks in advance for your help.
+1971 Ford F250 Camper Special
+3 speed auto transmission
+Engine - 390
[/QUOTE]
+Engine - 390
[/QUOTE]
Spoiler
+Engine - 390
+Engine - 390
Spoiler
In post 52-54 of this thread was how i got that piece on the shifter linkage.
https://www.ford-trucks.com/forums/1...special-4.html
EOSZ-7341-B (replaced C3AZ-7341-A; C7SZ-7341-D; C8OZ-7341-A; C9TZ-7341-A and etc) .. Nylon Selector Lever Bushing / Available from Ford
This nylon bushing 'snaps' into the selector lever.
1968/91 F100/350 A/T / Misc: 1963/79 FoMoCo Passenger Cars; 1980/88 Thunderbird/Cougar; 1980/91 Crown Vic/Grand Marquis/Town Car and etc etc etc!
One TN source: AUTO NATION FORD in Memphis TN has 3 = 866-219-5755.
72CC428
12-07-2018 08:25 PM
72CC428
11-19-2018 10:55 PM
