1978 - 1996 Big Bronco
Kid's Bronco project
Old 03-22-2018, 10:53 AM
Toyman's Avatar
Toyman
Toyman is offline
Have you checked top dead center on the distributor to see if it had jumped time. If the timing chain is worn badly 1 backfire can make it jump a few teeth.
Old 03-23-2018, 07:10 AM
Redark1's Avatar
Redark1
Redark1 is offline
like the other guy just posted you need to check the timing. if you keep pouring gas down the intake then its getting the plugs wet and that's making things worse. fill the carb use some spray and put some jumper cables on it from another source to get the cranking speed up.
Old 03-26-2018, 10:52 PM
lanneinbc's Avatar
lanneinbc
lanneinbc is offline
Can this be checked without a timing light? Waiting to see if we can borrow one.
Old 03-27-2018, 06:49 AM
Redark1's Avatar
Redark1
Redark1 is offline
you can kinda get it close. pull the plug on number 1 cyl and rotate it to TDC checking for pressure to come out the plug hole. then line up the timing tab to zero deg's. then check the relation with the rotor to number 1 cyl and adjust the distributor to give it some advance. hth
Old 03-27-2018, 07:54 AM
Toyman's Avatar
Toyman
Toyman is offline
Yes, what Redark said. Pull #1 plug and rotate around until it is on the compression stroke, then pull the cap on the distributor and see where the rotor is pointed. It should be aimed at where the number one spark plug is.
Old 04-09-2018, 07:41 PM
lanneinbc's Avatar
lanneinbc
He got it running! Pumped fuel directly out of a jerry can instead of the tank, and fixed the firing order
It still takes some coaxing to get it fired up, but once it's going it actually sounds pretty good. Will add video soon!
Old 04-10-2018, 02:40 PM
Redark1's Avatar
Redark1
Redark1 is offline
that's great to hear, one ataboy for him.
df85732
23
06-15-2018 10:27 PM
jayro88
07-16-2016 11:47 AM
erupert66
05-24-2015 09:04 AM
bk53
07-13-2013 04:09 PM
triassic
Electrical Systems/Wiring
04-11-2012 07:08 AM
Quick Reply: Kid's Bronco project
