84 6.9L IDI dually flatbed help
I also noticed that the factory Stanadyne fuel/water separator mounted on the driver side firewall has been bypassed. The fuel/water separator mounted forward on the block is from a 7.3L with a cast aluminum bowl/collector on the bottom. Is this common? Since I started it it runs like a champ.
Received 3,101 Likes
on
on
#28
No more than any other diesel... I'd just add powerservice or another normal lubricity additive just because - it's cheap and won't hurt anything.
Also, I've successfully run nearly 50 gallons 6+ year old diesel I found in a tank I bought...Smelled OK, so I figured it'd probably run just fine. And it did.
#29
84 F-350 dually 4wd flatbed, with 7.3L, not a 6.9
After changing the oil/filter, air filter, cutting out the soup bowl, new fuel/water separator I just found the block is stamped 7.3D U2 U523969*. I'm glad that the new parts are common between the 6.9 and 7.3. So, the transplanted 7.3 is connected to the T-19 4 spd. I guess I'll check the front and back differential to verify gear ratios and possible use of a ZF-5 from a 460 or newer IDI.
Any suggestions?
Any suggestions?
#30
