Protect Your RV Investments This Winter!
As camping season is coming to a close and you are thinking of going south for the winter or storing your RV, do you have proper security and storage options during the winter? At Torklift, we always believe that it’s better to be prepared than to have to deal with hundreds of dollars in repairs and replacement when spring comes around. Three things to consider when storing your RV are: do I have proper locks for my propane tanks, how protected is my shore power cord and do I have a spare battery that is stored safely throughout the winter?
The Fortress GasLock
We have a great solution to help prevent a worst-case scenario, which includes a thief trying to remove your propane tanks and cutting the lines, costing you upwards of $500 to repair and replace what was taken. The Fortress GasLock is designed to securely lock your propane tanks that are mounted to a trailer, towable or RV. It’s currently the only lock available specifically designed for LP tanks in the industry.
As an added bonus? The Fortress GasLock does not require tools for installation and only takes seconds to install. The propane tank lock does not interfere with LP tanks and can be filled while it’s locked.
Features of the Fortress GasLock Include:
- Avoid typical propane tank theft repairs exceeding $500
- Allows tanks to be quickly locked when mounted to trailers, towables and RVs
- Does not interfere with LP tank valves and can be filled while locked
- No tools, no modifications, installs in seconds
- Affordable investment
- Designed for dual tanks
- High impact powder coated military grade aluminum
- Fits available for all applications
- Only lock available for propane tanks in the industry
- Proudly made in the USA
Kit includes:
- One GasLock assembly
- Lock and keys
- Theft deterrent decal
The HiddenPower
One of the best way to avoid being a target for potential thieves is to just hide your products in plain sight! A great way to do this for your extra RV batteries is with the HiddenPower under vehicle battery mount. Thieves won’t even know you have a battery installed under your vehicle because your ground clearance isn’t affected by the HiddenPower – thus remaining hidden in plain sight!
The HiddenPower auxiliary battery is designed to be an extension of your RV's battery when your RV is plugged into your truck and will recharge via your RV's existing solar panels, generator, converter, etc. at the same rate that your RV's batteries charge.
Features of the HiddenPower Include:
- Add additional batteries under your truck bed that are always charged up
- Avoid wasting fuel and leaving your truck engine running while using electrical accessories such as lights, stereos, computer, etc.
- Power your accessories without turning your truck engine on by having them directly wired into the extra battery
- No-drill frame mounted with quick disconnect feature for battery service
- Kept constantly charged and RVing-ready by your RV and truck’s charging system
- Hidden when in use with no loss of ground clearance
- Works with group 24 to 31 batteries
- Designed for all types of batteries: lead acid, AGM, sealed, gel cell, etc.
- Legendary Lifetime Warranty
Kit Includes:
- Frame mount bracket
- Group 24 to 31 battery box
- Installation hardware
The Fortress PowerLock
When you purchased your RV, you knew there were certain locks and security items you would need to obtain to keep you and your camper or trailer as safe as possible. But did you know that your shore power is an integral part of your trailer and is a target of potential thieves?
Not only can a criminal steal the copper in your cord, but could cause hundreds of dollars in damage cutting them out. We have a great solution to help prevent your cord from being cut out and stolen. It’s your shore power cord, one of the main life lines to your trailer and camper! The Fortress PowerLock is designed to cover your shore power cord access door to protect your RV power cords from being cut and stolen. It’s currently the only lock available specifically designed for shore power cords in the industry.
Features of the Fortress PowerLock Include:
- Lock covers shore power cord access door to protect RV power cords from being cut and stolen
- Prevents theft associated with opening access door and removing power cords
- Easy installation
- Lock and keys included
- Available in black or white high impact powder coat aircraft grade aluminum
Kit includes:
- Fortress PowerLock
- Two keys
The PowerArmor
Now that it’s getting frosty outside, it’s time to start thinking about storing your trailer and batteries for winter and protecting them from potential thieves. Instead of having to bring your batteries inside your home, with the PowerArmor Solar you can leave them safely on your trailer. The battery box bolts directly to your RV, trailer tongue, boat, camper bumper and more.
Torklift’s battery box comes with a solar panel from the leader of RV solar power, Zamp Solar. This solar panel can extend battery life fourfold. Let us repeat that: your batteries can last up to four times longer when they are maintained with the PowerArmor Solar. This translates to avoiding the time and money of re-purchasing your batteries. The solar panel trickle charges your battery even when there is no direct sunlight, and keeps charged batteries at the optimal level to maintain healthy RV batteries.
Features of the PowerArmor Include:
- Prevent common and expensive storage/battery theft (lock included)
- Maintains charge increasing the longevity of the batteries up to 400% to avoid premature battery replacement (solar only)
- Dual use for securing batteries and other gear
- Bolts to your RV, camper bumper, boat, truck, van, etc.
- Heavy gauge diamond plate aluminum for maximum durability
- Designed specifically to access RV batteries avoiding interference with your RV
- Uses a 10 watt solar panel (solar only)
- Comes in bright tread diamond plate featuring black high impact powder coat frame
- Multiple box sizes available holding up to five batteries
- Adjustable dividers for custom size compartment storage (PowerArmor Max only
- Acid neutralizing battery mat to avoid corrosion
If you’re interested in purchasing any of these storage and security products from Torklift International, visit one of our Certified Dealers near you here. To contact us for more information, reach us at support@torklift.com or call our tech support at 800-246-8132. We are more than happy to help you.
Written by: Kerstin Stokes
__________________
Torklift International – Towing, Suspension, Tie Downs, Steps
Call me direct: 1-800-246-8132
Visit our Blog: http://www.torklift.com/blog
Torklift Sheryl
Vendor Specials, Discounts, Product Announcements & Group Buys
12-20-2018 12:58 PM
Torklift Sheryl
12-06-2018 07:00 PM
Torklift Sheryl
09-26-2018 01:48 PM
Torklift Sheryl
11-07-2017 01:07 PM
Torklift Sheryl
06-01-2017 06:08 PM
