Mild 300 build HEI Distributor - Page 2 - Ford Truck Enthusiasts Forums
Old 11-17-2017, 12:02 PM
old28's Avatar
old28
old28 is offline
old28 is starting off with a positive reputation.
Not trying to start a pxxxing match but I guess we won't know how long it will last until we try it or do we just assume that it's junk. I know what your saying.
I'm 72 so if it lasts 15 years i'll be happy as a hog in a mud bath.
Old 12-25-2017, 10:00 PM
old28's Avatar
old28
old28 is offline
With my mild performance 300 with RV cam, Offy dual port intake with autolite 4100 carb, 9.3 CR, HEI distributor, 50,000 coil and 8mm plug wires I am looking for the correct copper core Motorcraft plug. Are the old 44's that have been replaced with the SP435 the right plug? Is the gap .044"?
Some say to run EFI plugs as they have a little longer tip, What say?
Old 01-04-2018, 01:31 PM
rustywheel68
rustywheel68 is offline
rustywheel68 is starting off with a positive reputation.
I'd run the stock plugs, just re-gapped to whatever is recommended for the HEI systems. I think .044 would be fine.
Old 01-04-2018, 01:46 PM
F-250 restorer's Avatar
F-250 restorer
F-250 restorer is offline
F-250 restorer has a good reputation on FTE.F-250 restorer has a good reputation on FTE.F-250 restorer has a good reputation on FTE.
Hello there. That sounds like a nice build. I have a similar build and run the oem plugs with a .055 gap. I have since day one. I believe that with the DUI dizzy they recommend the 55 gap. Check their site.
I believe it is Harte3 who uses the efi plugs.
77 pickup
35
10-16-2017 03:49 PM
avellaneda13
11-26-2015 06:01 PM
bmwcarl
04-20-2015 09:35 AM
sgreen
Electrical Systems/Wiring
08-16-2002 06:19 PM
sgreen
08-16-2002 07:19 AM
Quick Reply: Mild 300 build HEI Distributor
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
