Hitch Falure
#46
From looking at the original pictures it looks like the hitch failure happened on the tubing towards the rear of the truck bed and using the goose ball as the pivot point when the rear tubing failed the the front frame pulled up. If this is the case then the stress occurred while pulling forward rather than pushing in reverse.
If he had been pushing backwards I would think the hitch fail would be in the tubing towards the front of the bed and as the weight pivoted on the ball the frame in the rear frame would have come up.
However, me too no engineer, so I may be way off base on this theory.
I hope we hear the final "what the heck happened" explanation on this one as I have the steel AUH rail mount version and the Rota-Flex which I will be putting the lockout kit on as soon as it arrives. FWIW I have about 5k miles on the AUH without any obvious issues. I just took a look last night and all looks straight and square.
#47
I asked Andersen if they were aware of this collapsed hitch. I assumed they were, and they gave a nice response. They have also increased the strength of the hitch.
We were recently made aware of this customer’s unusual circumstance and are currently working with them. We have been looking into all of the particulars with this one so we can figure out exactly what may have caused it.
On a side note, any bending problems like this with the Ultimate Connection are extremely rare - in fact, out of all of the units we have shipped since early 2011, we have only seen this happen to 2 other units total (which equates to approximately 0.00007%). In each of these cases the trailer did NOT detach from the ball –so safety was not compromised, and damage to the truck or trailer was either non-existent or minimal. For each one we were able to get a replacement unit to the customer promptly so they could continue their trips.
We did bring each of the bent units into our engineering dept. to look them over carefully. We were happy that we did to find any defect in the part itself. Since it is not really possible to determine if the problem was caused by installation error, or other extenuating circumstances, we just went ahead and made the decision to increase the strength of the Ultimate Connection (part 3220 and 3221) by 30% to alleviate the issue in the future.
Here at Andersen Hitches we continue to stand behind our product and we will always put the customer first. Along with a lifetime warranty on the Ultimate Connection itself, we also have a $5,000,000 supplemental warranty covering the frame and other damage that might occur. We do this because we have absolute trust in our products and want anyone who owns or purchases an Andersen Ultimate Connection to be assured of their purchase. I know of no other manufacturer in our industry that does anything like that.
Please contact us at customerservice@anderseninc.com if you have further questions or comments. Thank you.
#49
#50
I want to know what they did "to increase the strength of the Ultimate Connection (part 3220 and 3221) by 30% to alleviate the issue in the future". Without that the statement is just cya and feel good medicine from the marketing dept.
I bought the AUH 3220 just over a year ago and returned it, I want something more substantial.
#51
#52
#53
Andersen sent me the new poly (red colored) cone that does not cause shavings to come off the ball at no charge to me. The new cone is like a really hard bushing materiel you would see used for swaybars, almost like a delrin or something, but seems harder.
Andersen offered to replace the ball at no charge as well, but I didn't feel it was necessary but told them I appreciated the offer.
I have used the new cone/coupler many times since installing it and am very happy with the results. I have not seen any dents or deep scratches at all during my use of the AUH steel version.
They have always been very responsive with me. When we first installed the hitch and coupler we happened to be 1000 miles from home buying a 5th wheel trailer from a private party sight unseen. We installed the hitch (rails were mounted in the truck already) and coupler at a truck stop. The allen wrench set I brought did not have the depth required to install the 2 allen bolts toward the rear of the coupler. I got them installed, but stripped them out pretty good in the process.
When we got home, I contacted Andersen via email and told them that I would like to purchase 2 allen bolts because of my own mistakes. They sent me a set of 4 at no charge to me with no questions asked.
#54
It is the same ball in all models. I have seen a picture of a ball with gouges and would replace it if that happened. I am on the second ball simply because I got the slightly taller one with the funnel upgrade. I have no damage to either. Prior to the funnel, the locking mechanisms always worked easily. After the funnel, with less precise hookups by letting the funnel direct the ball, I found the locking sometimes took more effort. By trial and error, I determined not to drop the fiver with the ball forward in the funnel and no problems when the ball was behind the socket.
Edit: When I switched this May from the steel to the aluminum version, I noted the instructions said to torque the top bolt to 50 ft/lbs, but had seen comments in the forums about 60 being recommended. I also noted that Andersen said to torque again AFTER the fiver was on the ball so I did that and was really surprised by how loose the bolt was after hitching the fiver. I spoke with another AUH user who was unaware of the second tightening requirement, he did it and said it was solid now after showing signs of movement previously.
I have the ball at the lowest setting and the socket can't fit under the adapter, so I move the ball to the middle, torque the bolt, raise the nose and lower the ball to the bottom position.
I also had the problem after installing the red funnel of my allen drivers being too short. I found longer ones at NAPA and had to ask the guy at the counter to find them for me.
#55
Let's be serious here guys do you think I'm worried about my 20K Reese hitch collapsing because some part of the hitch may have been damaged because of all the stuff piled around the hitch over the last 17 years, the only thing that has been damaged is the handle because I had to much fireword back there. If I want to remove it it comes apart in 3 pieces that are easily handled, I never think about my hitch failing.
I would have a B&W but I can't have a hitch with a foreword moving handle because of my tool boxes. I took the B&W tour years back and they tested their hitch by giving them to delivery driver's from the HitchHiker plant for some real world testing.
Denny
Denny
#56
Denny
Denny
That does not mean that new products and ideas should not be tried out and implemented if they appear to be viable. Technology gets better and smaller, and that is where we are at with the AUH. I have stated more than a couple of times that the B&W is a great hitch (as others have) and was my first choice. That is until I found the AUH steel/5th wheel rail version.
Is it as reliable as your hitch, I think so. Is your hitch more reliable than the hitch in the picture on page 1 that is anchored by the gooseneck ball, my money is on yes. To each their own and I have 100% confidence in the STEEL/5th wheel rail mount style.
If my hitch ever shows signs of failing, I will pick up a B&W and chalk the AUH up to I tried it and didn't care for it.
Have fun and be safe out there, anything can and will fail eventually.
#57
Seen this type of failure before
Just a FYI, the below pictures were posted on the Grand Design Facebook page. It is still playing out on what caused the failure. A 2015 Momentum 380TH (42' long toy hauler with an empty weight of 15,500 lbs and 2950 lb pin weight) was being pulled by a Ford Dually. Speculation is that the Roto-Flex pinbox could have contributed to the failure. It happened at low speed, and neiher the truck or 5th wheel had any damage. By the way, the Andersen hitch isn't the only one to fail in like manner. I've seen a family member do the same to a Pullrite slider setup that again had the breakaway pull out during a sharp turn.
JMAC
Attachment 247975
Attachment 247976
JMAC
Attachment 247975
Attachment 247976
#58
I've seen this failure before. The breakaway cable was attached in a way that it allowed it to catch on something during a sharp turn, pulling it out and setting the trailer brakes. The driver thought it was just rough terrain causing the resistance to turning and instead of stopping, put the truck into 4WD low. As the truck tried to complete the turn, the Andersen hitch failed from the immovable trailer held by it's brakes.
Edit: I just realized this is an old thread that I have responded to before which is another reason I have seen these pictures before. LOL
#59
