Identifying parts, 400 rebuild
Just a quick question. I am pulling apart a 400 from my 77 F250 SC to rebuild. Once I pulled the heads, I saw stamped in the top of the pistons .030. I am assuming this means they are .030 over pistons. Is there a way to find out what my compression ratio is? Will these be marked with a part number some where? Haven't pulled out the pistons yet, but had time to ask my questions. Or, is there a way to measure?
Thanks.
Thanks.
Well, from you guys descriptions, I would say they are stock style. But with deck surfacing that should have happened when boring was done, and what i will do at machine shop, my compression will come up a little more. I am not looking for a drag motor, just a good running towing motor. I think a cam, 4 barrel and headers should help this out a bunch.
Will hopefully have the time to tear the motor down the rest of the way today. if I see any other markings i will post them with pictures.
Yes, early on the 400 could have had flat tops from the factory. I've came across a few sets over the years.
78ford_shortbox
10-19-2021 12:41 PM
400 Ford
25
02-19-2004 06:49 AM
