Standpipe help!!!
https://www.ford-trucks.com/forums/1501907-passenger-side-standpipe-advice.html
I left my passenger side lower in and stuck a new top half on it. My truck has 100K and, as best I can tell from Oasis, Carfax, and having 10mm hex heads on both standpipes, they were original. Lower o-ring on drivers side looked fine.
I made a tool and it did not cost more than $10.
I't made from a ¼-20 cap screw and some fuel hose that fits over the bolt.
The 2 aluminum parts just happened to be Rivnuts to act as a spacer. Really
anything that is sort like aluminum will work. The thumb nut was chosen for
the ability to allow you to pull on it. What you do is stick this into the top
of the lower section where it is down inside the rail and turn the nut down
so it's nice and tight and then PULL. If it slips out clean the oil off and try again.
One comment on the hose type use the stuff this does not have a slick surface.
you want a sticky rubber surface to grip with. With this tool there is less likelihood
of having pliers slip and drop metal fragments down the tube from the teeth ripping loose.
One thought : If I were to make one again I think I would just cut some
thick walled aluminum tubing for the spacer. That way they would not tip.
The guy that has a lathe could make a really nice spacer more like the
Rotunda tool Below.
Here is the top of the stand pipe for reference.
Rotunda tool Below.
Splatts
34
07-02-2012 05:11 PM
