1979 F250 460 auto - Ford Truck Enthusiasts Forums
1979 F250 460 auto
Old 10-22-2017, 08:53 PM
Fords and Dolmars Fords and Dolmars is offline
Fords and Dolmars is starting off with a positive reputation.
1979 F250 460 auto
I recently picked the truck up for my son. It has the 460 and is a 2wheel drive. It is slow to shift into second gear so I checked the tranny fluid and it was about a half of a quart low but it is the brownest smelliest tranny fluid I have even seen. I want to change the fluid and filter soon! The code on the dipstick says ESP M2C138-CJ oil. My question is what fluid is that? Is it type F or a mercon oil or what? Also what brand of fluid do you guys suggest and how many quarts do I need? I doubt if I can get the torque converter drained unless it has a accessible drain plug. Any help would be highly appreciated.
Old 10-22-2017, 09:53 PM
PA74F250's Avatar
PA74F250 PA74F250 is online now
PA74F250 is starting off with a positive reputation.
deleted my misinformation
Old 10-22-2017, 10:39 PM
Loosescrews Loosescrews is offline
Loosescrews is starting off with a positive reputation.
Should be Dex/Merc. And the torque converter has a drain plug accessible through bellhousing inspection cover. Next to one of the studs on converter
Old 10-23-2017, 06:42 AM
KULTULZ KULTULZ is offline
KULTULZ has a good reputation on FTE.KULTULZ has a good reputation on FTE.
Post ESP M2C138-CJ
Quote:
Originally Posted by KULTULZ 08-25-2007 View Post
CJ was superseded by DEXRON III/MERCON.
FORD has since dropped MERCON and has gone to MERCON V.
You should still be able to buy DEXRON III form another refiner.
Quote:
PENNZOIL DEXRON-III/MERCON Automatic Transmission Fluid
Suitable for use in applications requiring Ford M2C138CJ and Ford Type H fluids.
E4OD pukes when sitting wevie 1987 - 1996 F150 & Larger F-Series Trucks 2 05-10-2017 03:01 PM
Trans question bcaughhorn 1999 - 2003 7.3L Power Stroke Diesel 2 11-17-2016 05:37 AM
Help!! Oil not draining, overfilled, not driving?? ryansalay 1999 to 2016 Super Duty 33 07-23-2016 08:25 AM
What Brian had to say about water in tranny comsupany 1999 - 2003 7.3L Power Stroke Diesel 5 05-06-2016 10:41 PM
Mixing Mercon LV with Valvoline Max Life coolfeet Clutch, Transmission, Differential, Axle & Transfer Case 2 03-09-2016 07:48 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
