Need urgent help, stuck on interstate with anemic truck - Ford Truck Enthusiasts Forums
Old 10-22-2017, 01:21 PM
Jaime74656's Avatar
Jaime74656 Jaime74656 is offline
Another cautionary tale
Jaime74656 is a name known to allJaime74656 is a name known to allJaime74656 is a name known to allJaime74656 is a name known to allJaime74656 is a name known to allJaime74656 is a name known to all
1999 F250 stuck on side of interstate with anemic amount of power, half full of fuel, and running, can't get above 11mph if climbing a hill, 40 if on level ground, trans did seem to shift odd just before issue started like it was slipping into another gear, still drove forward however .
needing any possible assistance please.
Old 10-22-2017, 01:26 PM
HD Rider's Avatar
HD Rider HD Rider is offline
HD Rider has a great reputation on FTE.HD Rider has a great reputation on FTE.HD Rider has a great reputation on FTE.HD Rider has a great reputation on FTE.HD Rider has a great reputation on FTE.
Where are you located?
Did you get a SES light?
Smoke?
Old 10-22-2017, 01:27 PM
Walleye Hunter Walleye Hunter is online now
Walleye Hunter is a name known to allWalleye Hunter is a name known to allWalleye Hunter is a name known to allWalleye Hunter is a name known to allWalleye Hunter is a name known to allWalleye Hunter is a name known to all
How's EGT's and smoke? Hutch mod been done? How's the idle? First thing I'd guess is restriction of fuel flow somewhere. Is scanning it a possibility?
Old 10-22-2017, 01:45 PM
Sous's Avatar
Sous Sous is online now
Sous has much to be proud ofSous has much to be proud ofSous has much to be proud ofSous has much to be proud ofSous has much to be proud ofSous has much to be proud ofSous has much to be proud ofSous has much to be proud ofSous has much to be proud ofSous has much to be proud of
Someone had a very similar problem about 6 months ago, it was Steve who is an RV mechanic. His fuel pump would provide enough pressure to idle, but when applying fuel to the engine with the pedal the fuel pump would fall short. Do you have a fuel pressure gauge?
Old 10-22-2017, 01:50 PM
Jaime74656's Avatar
Smoke?
I64 West bound at exit 48, Kentucky
SES has been on sonde I bought the truck and has been running on with no issues, don't seem to see any smoke at art, nothing no black or clear smoke. Put fresh tank of fuel in also.
Quote:
i don't have my tablet with me at the moment so scanning may be hard to do. It idled between smooth and rough. At times it sound like my old international farm all tractor chugging in low. I just replaced the fuel pump with a new OEM bosh fuel pump a bout a week ago. Need to get into tank to inspect but I suspect H&H haven't been done yet (truck does not show signs of failed plastic foot yet).
if I let it idle and stop the gas while in park I can see a light haze of white smoke from the tail pipe. At idle nothing
Old 10-22-2017, 01:55 PM
It's hard to do when you get caught out on the road, with some luck a member will be close by. First thing I'd try would be to blow air from the pump back. Remove fuel tank cap first and you don't need a lot of air. That would blow stuff off of the in tank screens.
Old 10-22-2017, 02:10 PM
Jaime74656's Avatar
I will give that an attempt, from what I can tell (via butt dymomater) it feels more like it may be a bad batch of fuel.
update: after sitting for a bit and dumping the fuel bowl the truck has regained its power like nothing happened …the enigma strikes again…?????
Old 10-22-2017, 02:17 PM
Sous's Avatar
Gremlins are a bitch, but glad to hear you are back on the road.
Old 10-22-2017, 02:19 PM
da-bees da-bees is offline
da-bees is gaining momentum as a positive member of FTE.
Old 10-22-2017, 02:34 PM
Jaime74656's Avatar
Quote:
indeed, I have my brother attempting to come to the rescue, to follow me to a near by Autozone so I can pick up some new ZD-11 glow plugs, and test the batteries, I'm suspecting battery issues, as they go flat after a few days of sitting parked
Old 10-22-2017, 02:39 PM
Chevota_72 Chevota_72 is offline
Chevota_72 is starting off with a positive reputation.
Aftermarket glow plugs have been known to swell up in the heads and cause serious issues. Should stick with OEM.
Old 10-22-2017, 03:44 PM
hydro man 17 hydro man 17 is offline
hydro man 17 has a good reputation on FTE.hydro man 17 has a good reputation on FTE.
X2 on the GP's. Have you replaced any other parts/sensors with non-OEM parts? Would be worth investigating, but based on current status it looks like a fuel problem to me.
Old 10-22-2017, 04:11 PM
dn29626's Avatar
dn29626 dn29626 is offline
dn29626 has a great reputation on FTE.dn29626 has a great reputation on FTE.dn29626 has a great reputation on FTE.dn29626 has a great reputation on FTE.dn29626 has a great reputation on FTE.
...First thing I'd try would be to blow air from the pump back. Remove fuel tank cap first and you don't need a lot of air. That would blow stuff off of the in tank screens...
Agree.....
I am guessing that you do not have a fuel pressure gauge installed?
Old 10-22-2017, 05:30 PM
Jaime74656's Avatar
Quote:
Originally Posted by dn29626 View Post
Agree.....
I have a dual gauge set up, however the wires need to be redone, I have confirmed one battery is showing signs of failure so I will be replacing both batteries.
Old 10-22-2017, 07:50 PM
Colorado350's Avatar
Colorado350 Colorado350 is online now
Colorado350 has a very good reputation on FTE.Colorado350 has a very good reputation on FTE.Colorado350 has a very good reputation on FTE.
OEM GLOW PLUGS And SENSORS ONLY!
parts have started to arrive, 2005 build rockhounds4x4 Excursion - King of SUVs 45 11-14-2017 07:22 PM
Been away for awhile. Thor'sHammer 6.0L Power Stroke Diesel 0 02-13-2017 01:47 AM
Redtop, Yellowtop, Interstate, Costco TerranE 1999 - 2003 7.3L Power Stroke Diesel 25 11-29-2016 02:35 PM
Gutless 7.3 comtb 1999 to 2016 Super Duty 2 09-15-2016 07:18 AM
Getting better parking brakes? DieselCamper 1999 to 2016 Super Duty 6 06-08-2016 06:12 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
