74 F250 Dana 60 - Drum to Disc? - Ford Truck Enthusiasts Forums
Old 10-22-2017, 09:31 AM
amsetikas's Avatar
amsetikas amsetikas is offline
amsetikas is starting off with a positive reputation.
Hi Everyone,
Looks like the pads on my rear drums are in need of replacing so this has me thinking about an upgrade to disc brakes in the rear. I've been wanting to replace the master cylinder and brake equalizer(has a broken safety switch) so seems like a good time for all of that.
Hoping for some advice on what I should consider in doing this and if anyone has suggestions on any kits etc that exist to make this easier.
Appreciate any advice from others who have done this.
Andrew
Old 10-22-2017, 10:33 AM
hamviper hamviper is offline
hamviper is starting off with a positive reputation.
Been looking at this for a while as well, this is one that comes up a lot and has a parking brake, important for me with a manual
2660
Good luck
Old 10-22-2017, 10:54 AM
Jeff Watts's Avatar
Jeff Watts Jeff Watts is online now
Jeff Watts is gaining momentum as a positive member of FTE.
you can use front discs, and Cadillac calipers that have a built in e-brake.the only "custom" part needed is the mounting bracket/backing plate. They aren't crazy expensive.
Old 10-22-2017, 08:19 PM
650's Avatar
650 650 is offline
650 is starting off with a positive reputation.
For my 76 I am gonna swap in a 14bolt rear from a Chevy truck to get a stronger axle and get disc rear brakes with the factory parking brake inside the rotor.
Dont forget to factor in all the little things. Those are what will kill you on a project like this.
Old 10-22-2017, 09:02 PM
J ballan's Avatar
J ballan J ballan is offline
J ballan has a good reputation on FTE.J ballan has a good reputation on FTE.J ballan has a good reputation on FTE.
I'm also curious about this swap. Looks like 77 chebby K20 front rotors, calipers, pins and hoses. How about brackets? The weld on are cheaper but are they as good?
Old 10-22-2017, 10:39 PM
Rollingscrapmetal Rollingscrapmetal is offline
Rollingscrapmetal is starting off with a positive reputation.
I did this a while back when I swapped in a not destroyed axle I went with a company called lugnut 4x4
it came missing a part I got a new one immediately shipped to my dads then to me where it got lost in the mail sent back later lost in the house etc. Eventually I got it
It's a good kit uses 90s ifs parts I'm pretty sure dropped straight on shy of rusted bolts and broken lug nuts and 100-150 more than just fixing the destroyed drums
now just the front...
Old 10-22-2017, 11:48 PM
Jeff Watts's Avatar
Just remember that Chevy rear axles are narrower than the front, so your truck is going to look kinda goofy.
Old 10-22-2017, 11:50 PM
Jeff Watts's Avatar
Oh! And your wheels won't fit. Chevy 3/4 ton and 1 ton trucks have larger hubs. Bolt pattern is the same but the hole in the center will be too small.
Old 10-23-2017, 02:08 PM
HIO Silver's Avatar
HIO Silver HIO Silver is offline
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
Quote:
Originally Posted by amsetikas View Post
Hi Everyone,
Andrew
Visit TSM Manufacturing: Ford Truck Rear
Old 10-23-2017, 09:43 PM
march's Avatar
march march is offline
march is gaining momentum as a positive member of FTE.march is gaining momentum as a positive member of FTE.
Quote:
Fairly simple and cheap. E-brake is the issue. I did this inexpensive method and later added this NP 205
IMG 1126
New bracket for disc brakes
Old 10-23-2017, 09:58 PM
J ballan's Avatar
Quote:
IMG 1126
Sweet looks good. I don't need a eBrake so I'm going the cheap route.
Old 10-24-2017, 01:03 PM
650's Avatar
650 650 is offline
[/QUOTE=Jeff Watts;17542928]Just remember that Chevy rear axles are narrower than the front, so your truck is going to look kinda goofy.[/QUOTE]
The rear dana 60 is already narrower than the front axle, but they are both 67" wide, so it will look the same as it already did from the factory.
Quote:
You got that backwards. The 14 bolt hub is 4.5", but the Dana 60 hub is 4.75"
Rear disc brake conversion for 93 F150? shore 1987 - 1996 F150 & Larger F-Series Trucks 19 08-24-2017 11:24 AM
1993 F350 4x4 Rear Disc Brake Conversion Wilde Ford 1987 - 1996 F150 & Larger F-Series Trucks 29 01-03-2017 05:43 PM
Eaton 17-a disc brake swap skheemer Large Truck 6 09-12-2016 07:12 AM
4 wheel disc brakes for 76 highboy... Catanna69 1973 - 1979 F-100 & Larger F-Series Trucks 15 08-29-2016 09:52 PM
rear Drum to disc conversion Multipierce 1997 - 2003 F150 18 06-01-2016 12:30 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
