Stock Covers with Aftermarket Rockers
What engine , a 351W? If so you will have use some taller after market type valve
covers to clear full roller rocker arms. I have seen special spacers that were available
in the past to allow the use of stock valve covers with full rollers. One other thing
that you might want to consider, is to use comp cams roller tipped rocker arms. They
do fit under stock rocker covers. That's what I run on my 351W.
I had the same issue with my current 460 build. I am going with a full hydraulic cam/ lifters and rocker arms as well. I ended up finding a new in the box vintage set of Ford Motorsport valve covers (before they became “Ford Performance”) and opted for those. I wanted something vintage from the 80’s to go with the truck. I thought about the spacers option but decided to go with a taller valve cover for simplicity sake. Still era correct, just not factory original.
bruno2
10-22-2017 04:53 PM
Goodold71
08-06-2003 08:14 PM
phantom429
03-14-2003 09:29 PM
