What funnel do you use to fill the DEF tank? - Ford Truck Enthusiasts Forums
2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Old 10-21-2017, 01:50 PM
Looneybin Looneybin is offline
Looneybin is starting off with a positive reputation.
Just wondering what others are using to pour in the DEF. I have arthritis in my wrists, so I need to use both hands to hold the jug of DEF. Does anyone have a funnel they can recommend that can sit independently in the tank / reservoir opening while I pour in the DEF?
Also, I've already looked into truck stops with DEF pumps, but there are not any near me. So that is not an option.
Thank you!
Old 10-21-2017, 01:54 PM
LOWRPMTORQUE LOWRPMTORQUE is online now
LOWRPMTORQUE is starting off with a positive reputation.
I use a transmission funnel. It fits in the filler neck perfect and allows for a quick fill with no spills.
Old 10-21-2017, 01:58 PM
A&Pmech A&Pmech is offline
A&Pmech is starting off with a positive reputation.
If you buy the 2.5 gallon jugs they come with a hose that fits right inside the neck.
Old 10-21-2017, 02:06 PM
cficare's Avatar
cficare cficare is online now
cficare has a good reputation on FTE.cficare has a good reputation on FTE.
Go to the dealer and buy the Ford special-purpose filling hose. It has a vent tube which allows easy filling without over-filling. I paid less than $7 with tax for mine.
Old 10-21-2017, 02:40 PM
69cj's Avatar
69cj 69cj is offline
69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.
Quote:
^^^ What he said.
Old 10-21-2017, 03:18 PM
brandontolentino brandontolentino is offline
brandontolentino is starting off with a positive reputation.
+1. I bought that same filling hose from Amazon. The vent also speeds up the filling process, so you don't have to hold the jug up so long.
Old 10-21-2017, 03:21 PM
jhonathank jhonathank is online now
jhonathank is starting off with a positive reputation.
I don't know if you have any larger truck stops near by, but I typically just go through the truck fuel lane and get DEF at the pump.
Old 10-21-2017, 03:23 PM
_hedge_ _hedge_ is offline
_hedge_ is starting off with a positive reputation.
I also go to the pumps, I hated using the jugs.
Old 10-21-2017, 03:54 PM
saskowner saskowner is offline
saskowner is starting off with a positive reputation.
If you use a funnel be careful not to fill it to the top if you live in a cold climate. It needs some room to expand when it freezes.
Gary
Old 10-21-2017, 05:04 PM
digitalagedad digitalagedad is offline
digitalagedad is starting off with a positive reputation.
+1 easier than holding the jugs and less likely to spill it on truck or you
Old 10-21-2017, 05:38 PM
Is the part # for the referenced hose pm27n?
Old 10-21-2017, 05:40 PM
Quote:
That's the one I got, FYI amazon has it also
Old 10-21-2017, 05:44 PM
Toledo Toledo is offline
Toledo is starting off with a positive reputation.
Old 10-21-2017, 06:10 PM
cficare's Avatar
Yes .. PM-27-N is the PN on mine.
Quote:
Originally Posted by Toledo View Post
The hose you get with that item is a generic fill hose and does not limit the amount of DEF you pour in. The
Ford hose Ford hose
includes an internal vent tube which allows faster filling AND stops the filling at the proper level. Over-filling your DEF tank has consequences.
Old 10-22-2017, 10:48 AM
Thanks so much, everyone! I appreciate the time you all took to respond to my post and help me out.
I will pick up one of those Ford nozzles for the DEF. I didn't even know they existed. Great info!
DEF Pronunciation txsd 2017+ Super Duty 32 10-08-2017 12:13 PM
DEF use mxer0022 6.7L Power Stroke Diesel 11 06-07-2017 11:05 PM
Awful mpg/drinks DEF like sailor Roy 17 Oaks 6.7L Power Stroke Diesel 59 11-14-2016 05:08 PM
DEF Consumption troverman 2017+ Super Duty 24 11-11-2016 10:32 AM
Javi's Rules for DEF Usage.. Javi1 6.7L Power Stroke Diesel 72 10-10-2016 07:13 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
