fuel pump lobe direction vs cam gear direction
Why would it matter? I forget if they look any different from the one or two piece style on gas engines, but it should be installed such that it cannot rotate on the cam. Closed end toward the cam and open end toward the front. The eccentric ("fat part") faces out from the cam centerline.
OK, obviously I should explain myself better:
I know that it doesn't matter for the fuel pump, and only goes one way. I have a motor with the IP gear off of it, and I need to figure out if the engine is at 0 or 180. I can either pull the valve cover, mess with a glow plug and cranking it over... or just look at which way the lift pump cam is facing.
Because it's on the cam gear(and keyed in place), it will always point the same direction at the same # of degrees. So, if I find out that it's pointed, say, towards the passenger side at 0 degrees of cam timing, I can just look down and see it. If it's pointed towards the passenger side, I'm at 0. If it's driver's side, I'm at 180.
Make any sense?
So, to clarify, I just need to know what angle the fat part of the lobe (roughly) is, with the cam gear at 0 degrees of rotation(0 facing down, Y facing up I believe)
Make any sense?
46yblock
16
02-23-2012 02:45 AM
FoMoCo390
08-23-2009 06:54 AM
3Mike6
13
06-11-2007 12:25 PM
