1979 F100 351w - Ford Truck Enthusiasts Forums
1979 F100 351w
Old 10-21-2017, 11:09 AM
XenosF100 XenosF100 is offline
XenosF100 is starting off with a positive reputation.
1979 F100 351w
Just picked up a 79' F100 with a 351w in it, previously refit.
Figured it would be quicker than it is and more hot rod. Any advice on what to look for in terms of how to get more speed and HP onto the back wheels.
Its 4x4, got 35's on er, engine is been build up and chromed out, new 750cfm carb just swapped out and reinstalled/old one was gummed up, 4 speed shifter. 1st gear is not used, too much torque, rock climbing gear I assume.
Its my weekend driver and I just want to be able to tool around and light em up when needed. But I can't get the torque out of 2nd into 3rd, and 4th is just a sleeper currently.
Any advice would be appreciated.
TY
Old 10-21-2017, 11:58 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by XenosF100 View Post
Just picked up a '79 F100 with a 351W in it, previously refit.
Its 4x4.
351W's not installed until 1981 in F150/350 & Bronco, but not in F100's.
There were no F100 4WD's after 1976.
Post the VIN to verify what your truck is.
Old 10-21-2017, 12:04 PM
meangreen92's Avatar
meangreen92 meangreen92 is online now
meangreen92 has a good reputation on FTE.meangreen92 has a good reputation on FTE.meangreen92 has a good reputation on FTE.
It takes a lot to push around a big heavy old 4WD truck on 35s. 750 CFM sounds a little large for a stock 351. You could grow the engine into the carb with a good aftermarket intake manifold, some good heads, and a higher revving cam. If you're on a smaller budget, look into some Explorer GT40 heads from the junk yard. I would thnk that a 351 would still benefit from the newer heads, even though they were designed for 302s.
Old 10-21-2017, 09:51 PM
palmrose2 palmrose2 is offline
palmrose2 is starting off with a positive reputation.
IMHO anyone that would swap a 351M/400 for a 351W is ignorant or an idiot. There is a reason that we are familiar with the term clevor.
Good luck.
Old 10-22-2017, 11:01 AM
Jeff Watts's Avatar
Jeff Watts Jeff Watts is online now
Jeff Watts is gaining momentum as a positive member of FTE.
My first thought was 35's on stock gearing. and post a pic of the motor.
Old 10-22-2017, 05:45 PM
Old 10-22-2017, 05:52 PM
Thanks Guys.
My bad they are 33's
The truck has been converted to a 1ton chassis/8 lug
I just posted some Pix of the truck and engine.
351W is not stock, Alluminum manifold and edelbrock headers, with the edelbrock carb. Engine is tight, runs well, just can't seem to get real power through the gears onto the street. Lags from second into 3rd?
the dash has been all redone, so vin not showings, but title has listed as 79 F100. It's definitely not stock, original owner and his dad (buddies of mine) did all the work about 20 years ago.
Old 10-22-2017, 06:12 PM
Hotrod_Merc's Avatar
Hotrod_Merc Hotrod_Merc is offline
Hotrod_Merc is starting off with a positive reputation.
The resto has certainly held up. Good looking truck.
As others have said, the bigger tire and those heavy wheels won't translate to hotrod performance.
I would start checking the timing and retune the carb. Edelbrock has the manual on the website. you can move the accelorator linkage to get more fuel or less when you hit the throttle, try moving a notch to change the stroke. Check your floats, maybe they are set too low.
Check your plugs for fouling or pitting. Find out if its getting enough or too much fuel. Check the gap too.
Check your ignition wires for resistance. If it is an old resto, things might not be up to snuff.
Take the cap off and clean that distributor, could be getting poor spark from corrosion.
You could try using the manifold vacuum port on the driver side of the front of the carb for your vacuum advance. The driver side pulls manifold vacuum and, tuned/timing set correctly could provide better response.
These are all things that don't cost money and will help you get to know your truck better. From there you can start to consider "upgrades".
Also make sure those brake hoses are not rubbing on the steering shaft. You might want to secure them better. And it looks like your brake booster vacuum line is hooked up to the pcv port on the carb. You need full manifold vacuum which is from the back port of those carbs only.
And I cannot tell what your pcv is hooked up to, but you might want to hook that up to the front of the carb where it is meant to be. Not ideal to have full manifold vacuum on your pcv.
Old 10-22-2017, 06:15 PM
J ballan's Avatar
J ballan J ballan is offline
J ballan has a good reputation on FTE.J ballan has a good reputation on FTE.J ballan has a good reputation on FTE.
I'm going to go out on a limb and say that's a 351M/400 which would make more sense. Also as far as the 8 lug wheels I'm betting he used heavy duty outer Cs on a F150 Dana 44 judging by the radius arms. If it was a F350 chassis it would probably have leaf springs out front. Non of this is bad news for you just trying to figure out what we are dealing with.
Old 10-22-2017, 06:21 PM
J ballan's Avatar
or it's just a F250? Post the VIN up and that should help. The only way to tell the difference between a 351M and a 400 is to measure the stroke. 351m=3.50" and the 400=4.00". My bet is it's a 351M and if that's the case find a 400 crank and get some TMyer pistons. Then you will have no problems throwing around your 33" tires.
Old 10-22-2017, 06:23 PM
Appreciate the tips Hotrod.
She sat in a shed for about 12 years until I just brought her back to life. So I figure there are definitely some items off a little due to the time she slept.
Old 10-22-2017, 06:26 PM
J ballan's Avatar
If it sat for 12 years check your mechanical advance. They were famous for seizing up in those HEI distributors.
Old 10-22-2017, 06:28 PM
10/4 J ballan, I'll get da vin and that's gonna tell a lot. Definitly 351W, so the 400 crank and pistons sounds like a good fit.
Old 10-22-2017, 07:24 PM
A whole lot of really good body work went into this truck. You're going to have to share more photos. I am really impressed that the filled markers were done right. Much of the 'custom' body work you see would have cracks by now. And shaved drip rails and filled the seam on the roof.
And is the gap from the cowl to the fender filled? The labour and materials that went into paint and body has got to be closer to 8-10k.
Given 12 years ago, I am surprised/thankful it has door handles.
You have a really nice truck to start with, I can't stress enough the importance of tuning and getting it dialed in.
Seems like they just kept throwing money at it until they lost interest?
edit: holy crap did they spend money. I was looking at the p/s pump, that is a fancy canned ham. Billet reservoir?
Old 10-22-2017, 07:39 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
Your engine is a 351m or 400. A 351W looks like so. Note the water outlet in the intake manifold (where the red rag is), and the trapezoid shaped valve covers.
http://www.allfordmustangs.com/forum...inefront01.jpg
If it is still a 351m, it is making about all the power it's going to make with those add on items. Real power from a 351m requires a 400 crank and some pistons that yield compression, plus a cam.
5.8w roller build / MAF & Fuel Sys Setup. Badlildoggy 1987 - 1996 F150 & Larger F-Series Trucks 8 07-18-2017 11:59 AM
Time for a new engine need help deciding ss27gogeta 1987 - 1996 F150 & Larger F-Series Trucks 58 06-21-2016 07:10 PM
302 built for torque? hail destroyer 1973 - 1979 F-100 & Larger F-Series Trucks 6 06-21-2016 06:08 PM
351w to 460 with .60 bored over questions. BrandonSpringle Engine Swaps 1 12-21-2015 01:18 PM
1976 F100 C4 to Manual Swap advice needed 76F100Custom 1973 - 1979 F-100 & Larger F-Series Trucks 9 12-05-2015 10:14 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
