Camper package or heavy service front suspension
i posted this on the 2017+ SD site, but thought I might get a better response from the towing Forum.
So I’m a rookie to SD trucks as well as one day in the future plan to buy a fifth wheel( first learn the truck).
I want the 3.55 gears and when building the F350, I try to leave out these packages, but it will default me to the heavy service front suspension as soon as I pick the 3.55 gears( I understand you can also use the camper package as well). The truck will be my everyday ride so I’d prefer to not have either because even Ford has a disclaimer that an unloaded ride will be affected by these options.
So since I evidently must have one of these with the 3.55 choice, which of these would affect the unloaded ride the least and/or might be beneficial when towing a fifth wheel when that time comes.
Good to know. Thanks. Is one of these options more beneficial for fifth wheel towing?
The stiff front springs IMO opinion are a good idea, especially when towing at or near your trucks GVWR. Plus, over time the spring settle a bit. As mentioned camper package does add sway bar. Although there are better aftermarket solutions for that.
One thing to consider, is whether or not you could deal with the extra 18" length by going to the LB. The reason I bring it up, is you then get the 40+ gallon fuel tank and no worries about whether you would need a slider hitch or not.
I'm currently in a F350 CC SB, and everything about it is great, except for the measly 26 gallon fuel tank. Which when towing means filling up about every 200 miles. I get between 8-10mpg depending on wind and my speed, and leaving a cushion of fuel. My next one will be the long bed.
EDIT: Just wanted to add that I am aware I could add a Titan or Transferflow under body tank, but the cost of those are pretty prohibitive for something that you cant take with you when you sell the truck.
I ordered with both camper/plow pkg. on my 17’ 350 regular cab and it rides great! I use it for work and empty or loaded it works for me. I went with with 4.30s in the rear with the locker and pulls nice with my 15k trailer, I don’t worry about mileage anyway I buy my trucks to work. Wrong ratios cause lots of heat in the drive line and that’s going to cost you sooner or later!
If your wanting a "good" ride unloaded you better look at a second truck as a daily driver. As far as gearing, you need to decide what kind of weight 5er you will be pulling and where (mountains/flat) before deciding on gearing. And as previously noted if your going to be pulling a 5er you NEED the camper package.
BTW - It's a HD truck, they all ride like a tank.
If you are going to pill a 5th wheel, I'd opt for the camper package. I did on my last 3 Super Duty F250s. In addition to the rear stabilizer bar, you gain the 7 pin trailer connection in the bed to plug the 5th wheel into.
I also get the 5th wheel prep package for the puck type hitch. It's nice to have a load floor without the rails when not towing.
If you get the fifth wheel prep, don’t you get the 7 pin trailer connection in the bed? So not a real benefit thenfor the camper package ?
I ordered the snow plow prep for my 2015 just to get the 3.55 rear. I believe in reducing engine load, plus the engine runs a little cleaner at higher RPMs. My DP-Tuner tow tune holds gears a little longer and it extended my regen intervals by not letting my engine bog down.
And the fifth wheel prep is just hands down the best deal going to get any hitch in the bed of your truck.
I have a '16 F250 CCSB 6.2 with the camper package and I don't find the ride objectionable. My wife sometimes complains, but the ride is really no worse than the F150 I used to have. It is a truck after all.
If you're going to pull a fiver, get the camper package. Don't even think about it, just do it. If you're smart, or at least smarter than me, you'll get the F350 and avoid the hit you'll take trading trucks when you upgrade the fiver - and everyone does.
And I wouldn't worry about the F350 ride because the F250 with the camper package has the F350 rear springs.
