Turbo issues
Old 10-20-2017, 07:58 PM
Mikenski's Avatar
Mikenski
Mikenski is offline
Turbo issues
my question is, when I punch the gas I only get turbo psi up to about 10psi, then stops, before if I'd have turbo psi up to 20psi + any ideas, it's a 07 f250 with no work done, it has 154k
Old 10-20-2017, 08:21 PM
Mich6.0's Avatar
Mich6.0
Mich6.0 is offline
check your connections and your charge air cooler, look for a blue o-ring around top and bottom tanks
Old 10-21-2017, 02:53 AM
Yahiko's Avatar
Yahiko
Yahiko is offline
Check all the boots and the pain in the butt plastic CAC tube for leaks.
Old 10-21-2017, 05:51 AM
Mikenski's Avatar
Mikenski
Mikenski is offline
Ok I'll check those areas today, and let you know thanks for the help
Old 10-21-2017, 08:36 AM
69cj's Avatar
69cj
69cj is offline
If you see oil on the boots it is seeping. If oil can get out so can boost. The boot leaks are usually in the hardest spot to see. Murphy's law.
Old 10-21-2017, 09:11 AM
2006F350KITT's Avatar
2006F350KITT
2006F350KITT is offline
Most likely will need to clean and or replace the turbo I had cleaned mine 6 years ago for the same kinda issue and just this summer the unison ring seized up again. I just bought a new turbo this time around
Old 10-21-2017, 01:37 PM
Mikenski's Avatar
Mikenski
Mikenski is offline
Ok I just checked the hoses and boots, and the black plastic pipe, cold side into the elbow had alot of old oil on it, cleaned it up and checked, no cracks or holes in any of the boots or piping
Old 10-21-2017, 02:15 PM
jsm180's Avatar
jsm180
jsm180 is offline
If it isn't building enough boost it will throw codes. What are you reading boost with?
Old 10-21-2017, 08:10 PM
Mikenski's Avatar
Mikenski
Mikenski is offline
It will only build boost to 10psi, after that the rpm will shoot through the roof, until I back out of it
Old 10-21-2017, 08:11 PM
Mikenski's Avatar
Mikenski
Mikenski is offline
It will only build boost to 10psi, after that the rpm will shoot through the roof, until I back out of it, and there are no codes coming up, even after I punch it and the turbo stops at 10psi, and rpm shoot up
Old 10-21-2017, 08:43 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
Remove the MAP hose from the manifold and check for any
goo in the fitting that threads into the manifold and then gently
remove the hose from the sensor and check it.
trevorrules
06-21-2015 04:16 PM
bobracing
13
04-27-2013 12:01 AM
6.9lXLTf250
15
07-04-2010 06:39 PM
05chop
General Diesel Discussion
12-11-2008 10:20 AM
berners
03-17-2004 09:42 PM
Quick Reply: Turbo issues
